Hi tpwang, please also refer to comment #20 to do check first.
the carried board and the core board is buyed form your company
I only burn the os image ,and burn successfully the emmc board;
I can not the board,after finished,
log:
I only burn the Jeston Os image:
I can not the emmc board
and the carried board and the core board is buyed form your company
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083177238
Starting kernel …
[ 1.067949] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.129361] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.135680] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100 [ 1.156580] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.162874] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.176245] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.182560] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.195923] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.202238] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.215599] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.221947] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.230254] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.230693] tegradc tegradc.0: hdmi: edid read failed [ 1.273545] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.273577] imx219 7-0010: board setup failed [ 1.297689] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.297719] imx219 8-0010: board setup failed [ 1.362429] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.362432] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.374256] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.374260] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.379245] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.379248] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.383892] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.383896] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.383899] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.383904] hpd: edid read prepare failed [ 1.640216] cgroup: cgroup2: unknown option "nsdelegate" [ 2.762275] using random self ethernet address [ 2.766781] using random host ethernet address [ 2.822857] using random self ethernet address [ 2.827393] using random host ethernet address [ 3.108879] random: crng init done [ 3.113512] random: 7 urandom warning(s) missed due to ratelimiting [ 6.744047] Please complete system configuration setup on desktop to proceed... [ 14.581102] tegra_i2c_handle_xfer_error: 11 callbacks suppressed [ 14.581107] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50Hi tpwang2000,
Please just use one topic to track your issue. I saw you have filed another one. Lets track your issue there.
