Version: L4T R32.6.1
I burn the fuses with the setting “PKC”
The securedevice is failed to cold boot after burn the signed image, no matter I press the reset button or re-connect the power, it keeps on RCM, but flashing device with image created by PKC is working. Status summary is as below
may I know what’s the flashing messages, it’s complete without errors?
would you please also setup serial console to gather the TX2 bootloader logs for reference,
thanks
hello edward1_lin,
I would like to confirm which TX2 platform you’re using, for example, is it TX2 or TX2 4GB?
BTW,
are you using the SDKManager to download all JetPack-4.6 tools (i.e. tegraparser_v2)?
could you please have a try to flash with previous release version to narrow down the issue, thanks
