We have a custom carrier board for the NX module and we would like to be able to update the image (bootloader, kernel and rootfs etc.) in the field by inserting a USB thumb drive with the necessary tools (nvidia flash tools) and image to do the upgrade. For example, we were considering running the ./flash or the ./nvmflash from an mfi tar ball from the USB stick to perform the upgrade.
From what I can tell, all of the nvidia tools (flash, nvmflash) require the NX module to be in recovery mode to work. Recovery mode appears to put the NX module in a state where the USB ports are no longer visible.
My questions is: Could you recommend a tool and procedure to perform the upgrade I described in the first paragraph.
Malcolm
