Flashing AGX Orin from ubuntu 20.04 stuck on “Sync'ing system.img ... ”
I am trying to update the RT kernel for my AGX Orin. When I run “sudo./flash.sh jetson-agx-orin-devkit mmcblk0p1” on UBUNTU20.04 on my personal PC in AGX Orin recovery mode, It’s stuck in "Sync’ing system.img… ", has been stuck here for more than two hours, I think this is not normal, may I ask where there may be a problem, my previous compilation kernel did not encounter any error.
This is the output at the terminal
terminal.txt (18.2 KB)
./flash.sh: 行 2860: python:未找到命令
你確定之前這台主機能燒錄嗎? Compile kernel跟能不能燒錄是完全不相關的事情
我之前是通过SDK Manger烧录的系统,版本是r35.2.1,但是由于ethercat通信需要实时内核,按照官方的教程https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html#to-build-the-real-time-kernel
但是官方的r35.2中没有相应的实时内核包,
所以我从https://developer.nvidia.com/embedded/jetson-linux-r3521
下载源码尝试编译烧录,我的过程是:
cd Linux_for_Tegra/source/public
tar –xjf kernel_src.tbz2
tar xf Jetson_Linux_R35.2.1_aarch64.tbz2
cd Linux_for_Tegra/rootfs/
sudo tar xpf ../../Tegra_Linux_Sample-Root-Filesystem_R35.2.1_aarch64.tbz2
 tar xjf aarch64--glibc--stable-final.tar.gz
sudo apt install build-essential bc
TEGRA_KERNEL_OUT=/home/robot/Jetson_AGX_Orin/Linux_for_Tegra/source/public/kernel/output/
export CROSS_COMPILE=<cross_prefix>
export LOCALVERSION=-tegra
cd kernel-5.10/
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
scripts/rt-patch.sh apply-patches
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j2
cd $TEGRA_KERNEL_OUT
cp arch/arm64/boot/Image /home/robot/Jetson_AGX_Orin/Linux_for_Tegra/kernel/Image
cp arch/arm64/boot/dts/nvidia/*dtb /home/robot/Jetson_AGX_Orin/Linux_for_Tegra/kernel/dtb/
 cp arch/arm64/boot/dts/nvidia/*dtbo /home/robot/Jetson_AGX_Orin/Linux_for_Tegra/kernel/dtb/
sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install INSTALL_MOD_PATH=/home/robot/Jetson_AGX_Orin/Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./apply_binaries.sh
在重启进入recover mode后,在我的个人PC Ubuntu 20.04 lsusb中看到 7023 Nvidia core APX,之后再执行
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
就会卡在我之前提到的那里
你能確定一下如果你不改RT kernel的話這包確定能燒嗎?
我不确定,现在我的板子已经不能正常开机了,我应该怎么做呢,尝试从SDK Manger重新烧录还是尝试继续从源码编译烧录一个没有RT 的内核
我不太確定為何還會問說要怎麼做…
這跟板子的狀況沒有關聯
你就把你所有有關RT kernel build的東西拿掉只裝單純的BSP就可以了…
你自己給的步驟, RT kernel的地方不用做,只燒純粹的BSP (重新抓一包新的)
把RT kernel的东西拿掉后可以正常烧录,能进入系统
請問host上硬碟空間夠嗎?
空间是够的,个人PC有1TB空余,jetson有内置64GB,我又扩展了1TB 的固态硬盘
可以確認一下是不是RT kernel module加進去rootfs導致的嗎?
我觉得应该是的,也许有可能与我编译内核时的.config设置有关系?我在执行
这一步时选择的都是默认设置
我這裡解釋一下…你前面卡在的地方是你的host.
你kernel多加了設定都跟你的host無關… 跟你的.config加了甚麼無關.
我還是傾向是加完檔案之後的rootfs檔案過大導致system.img也跟著變大…
加了RT相关设置的roofts有7.6GB,我觉得不是因为空间不够的问题。
没有RT设置的roofts有5.4GB,但烧录时在system.img这一步很快就完成了。
如果是因为system.img文件过大,那也不至于卡在这一步两个小时。
你可以先試試看只做這三步
但不做這一步
看一下這樣還會不會卡住
另外35.2.1這版已經有點太舊了 建議你可以升到35.4.1再試試看
