Flashing and Installing on Jetson
hello,
I would like to flash and install it on my Jetson Orin NX using a carrier board. (no development kit)
So I came across an eeprom issue and solved it by changing 0x100 to 0x0.
But when using SDKManager, sdkm re-download about nvidia_sdk/L4T…
So it returns to the original 0x100.
Thanks, regards.
Then just don’t use SDKM for flashing. The command way should also do it.
I don’t really know what’s the point here.
Sorry, I mean I modify the this file
~/nvidia/nvidia_sdk/Jetpack_5_1.2._Linux_JETSON_ORIN_NX_TARGETS/LINUX_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-000.dts
like this.
but when I try to flash other boards, It is overwritten with 0x100 using sdkmanager.
I know, so I mean please don’t use SDK Manager for flashing to avoid overwritten.
Anything you don’t understand?
Okay, thanks.
Then I searched about mass flash, I read the initrd_flash.txt.
When I follow that [workflow3] I met this error.
How can I solve?
Dump the full log as text here.
Don’t give screenshots.
