I need to restore all partitions from non-SecureBoot enabled device (no fuse burnt) to SecureBoot enabled device (fuse burnt). I am using Orin Nano devkit with Jetpack 6.0.
[ Orin Nano (No FUSE burnt) ] ==> [ Orin Nano (SecureBoot with FUSE enabled) ]
- I guess it is possible to do it with backup restore tool if I use PKC file and SBK file with -u and -v option. But could you please confirm this before I actually consume another device FUSE?
# Backup sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-orin-nano-devkit # Restore sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r \ -u pkc.key -v sbk.key jetson-orin-nano-devkit
- Suppose I have mfi tar ball from the non-SecureBoot enabled device, I guess it is not possible to flash the mfi image to the SecureBoot enabled device. However, will it turn possible if I don’t burn ODM Production Mode FUSE but only PKC/SBK/OEM_K1 FUSE?
# Will this work if ODM Production Mode FUSE is not burnt? cd mfi_jetson-orin-nano-devkit sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only
- Related to the above question, is it possible to test SecureBoot without burning ODM Production Mode FUSE? Actually I have verified with burning ODM Production Mode FUSE that I can enable SecureBoot with FUSE as follows. But I’d like to know whether the same can be tested without ODM Production Mode FUSE or not before consuming another device FUSE.
# Generate keys and EKS
python3 gen_ekb.py \
-chip t234 \
-oem_k1_key oem_k1.key \
-in_sym_key sym_t234.key \
-in_sym_key2 sym2_t234.key \
-in_auth_key auth_t234.key \
-out eks_t234.img
# oem_k1.key contains the same value as OEM_K1 FUSE
# sym_t234.key, sym2_t234.key, and auth_t234.key includes randomly generated Hex strings
# Copy to eks_t234.img to Linux_for_Tegra/bootloader
# Copy sym_t234.key and sym2_t234.key to Linux_for_Tegts
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--network usb0 -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
-u pkc.key -v sbk.key --uefi-keys uefi_keys/uefi_keys.conf --uefi-enc sym_t234.key \
--erase-all --no-flash jetson-orin-nano-devkit internal
sudo cp bootloader/eks_t234_sigheader_encrypt.img.signed ./tools/kernel_flash/images/internal/
--erase-all --no-flash --external-device nvme0n1p1 \
-c ./tools/kernel_flash/flash_l4t_t234_nvme.xml \
--external-only --append jetson-orin-nano-devkit external
