We did our development with the R35.5.0 release and have successfully flashed the system multiple times without any issues. However, we are now encountering a flashing error that we haven’t seen before.
We would like to continue using the R35.5.0 package. Could you please provide guidance on how to resolve this issue?
Then what is changed here? Does this issue happen because you changed something?
What is the variable here? The module changed? The carrier board changed? The software changed?
We are using the same build for both the commercial SOM and the industrial SOM. The flashing process works fine on the commercial SOM, but we are encountering issues with the industrial SOM. Previously, the industrial SOM was also flashing successfully with this build, but we are now facing this issue unexpectedly.
For commercial som flash command:
sudo ./flash.sh Jetson-agx-orin-devkit mmcblk0p1
For industrial som
sudo ./flash.sh Jetson-agx-orin-devkit-industrial mmcblk0p1
