Flashing failed Depnds on failed component
Refer
Same problem as below but for Jetson Orin 64GB
Is the recommendation valid for Orin too ?
sudo i2cset -f -y 0 0x50 0xff 0xfa
Or is it a different code
I assume the recommendation is to type the above code and reflags from sdkmanager
Please first describe your issue so we know if it’s the same one.
Attached is the screenshot and logs
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_AGX_Orin_modules_2024-06-25_00-51-26.zip (185.8 KB)
Apparently they are not the same:
00:52:12.641 - Info: [   1.6552 ] Sending bct_br
00:52:12.642 - Info:
00:52:22.690 - Info: [   1.6985 ] ERROR:
00:52:22.690 - Info:  might be timeout in USB write.
00:52:22.728 - Info: Error: Return value 3
what should I do ? Is there a preferred usb cable ? Or have I put the ends in the wrong slot !! Or just keep retrying !
Anurag
It’s not about the USB cable…
It’s about the USB auto suspend being enabled wrongly on your host PC.
Thanks this worked
