I am setting up the TX2. I was in step 3 of the SDK Manager. I put the TX2 into recovery mode. I was able to see ‘NVidia Corp.’ when using the ‘lsusb’ command. However, I get the error in this title.
What is wrong?
Below is the text from the terminal.
Thanks in advance.
12:59:52 INFO : null
13:01:09 INFO : CUDA on Host : download 'CUDA on Host' success
13:01:09 INFO : Drivers for Jetson TX2 & TX2i : download 'Drivers for Jetson TX2 & TX2i' success
13:01:09 INFO : OpenCV on Host : download 'OpenCV on Host' success
13:01:09 INFO : File System and OS : download 'File System and OS' success
13:01:09 INFO : NVIDIA Nsight Graphics : download 'NVIDIA Nsight Graphics' success
13:01:09 INFO : NVIDIA Nsight Systems : download 'NVIDIA Nsight Systems' success
13:01:09 INFO : VisionWorks on Host : download 'VisionWorks on Host' success
13:01:09 INFO : DevTools Documentation : download 'DevTools Documentation' success
13:01:09 INFO : CUDA Cross Compile Package on Host : download 'CUDA Cross Compile Package on Host' success
13:01:09 INFO : install 'CUDA on Host' success
13:01:10 INFO : install 'Drivers for Jetson TX2 & TX2i' success
13:01:10 INFO : install 'OpenCV on Host' success
13:01:10 INFO : install 'File System and OS' success
13:01:10 INFO : install 'NVIDIA Nsight Graphics' success
13:01:10 INFO : install 'NVIDIA Nsight Systems' success
13:01:10 INFO : install 'VisionWorks on Host' success
13:01:10 INFO : install 'DevTools Documentation' success
13:01:10 INFO : install 'CUDA Cross Compile Package on Host' success
13:01:10 INFO : OpenCV on Target : Found file /home/rishabh/Downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : OpenCV on Target : Found file /home/rishabh/Downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : OpenCV on Target : Found file /home/rishabh/Downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : OpenCV on Target : Found file /home/rishabh/Downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : cuDNN on Target : Found file /home/rishabh/Downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : cuDNN on Target : Found file /home/rishabh/Downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : cuDNN on Target : Found file /home/rishabh/Downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : VisionWorks on Target : Found file /home/rishabh/Downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : VisionWorks on Target : Found file /home/rishabh/Downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : VisionWorks on Target : Found file /home/rishabh/Downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
13:01:10 INFO : Multimedia API : Found file /home/rishabh/Downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
13:01:11 INFO : TensorRT on Target : Found file /home/rishabh/Downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
13:01:11 INFO : CUDA Toolkit for L4T : Found file /home/rishabh/Downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
13:01:11 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -ne 1 ] >
13:01:11 INFO : command finished successfully
13:01:11 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -gt 1 ] >
13:01:11 ERROR : command terminated with error
13:01:11 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "NVidia Corp".
13:01:12 ERROR : command terminated with error
13:01:12 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "NVidia Corp".
13:01:30 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -ne 1 ] >
13:01:30 INFO : command finished successfully
13:01:30 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -gt 1 ] >
13:01:31 ERROR : command terminated with error
13:01:31 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "NVidia Corp".
13:02:12 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -ne 1 ] >
13:02:13 ERROR : command terminated with error
13:02:13 INFO : 0955:7c18 detected.
13:02:13 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
13:02:13 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
13:02:32 DEBUG : running command < [ `lsusb | grep -c "NVidia Corp"` -ne 1 ] >
13:02:32 ERROR : command terminated with error
13:02:32 INFO : 0955:7c18 detected.
13:02:32 DEBUG : running command < lsusb | grep 0955:7020 >
13:02:32 INFO : Jetson device is in recovery mode.
13:02:32 DEBUG : running command < lsusb | grep 0955:7c18 >
13:02:32 INFO : Bus 003 Device 007: ID e[01;31me[K0955:7c18e[me[K NVidia Corp.
13:02:32 INFO : command finished successfully
13:02:32 INFO : Verified, 0955:7c18 detected in recovery mode.
13:02:32 INFO : Start to install 'Device Mode Host Setup in Flash'
13:02:32 DEBUG : Device Mode Host Setup in Flash : running command < cd '/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH' -v='1.0' -l='/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' -L='/home/rishabh/.nvsdkm/logs/JetPack_4.2_Linux' -p='9343' -t='P3310' -e='undefined' >
13:02:32 INFO : Device Mode Host Setup in Flash : [ Disk Avail:350.01 GB ]
13:02:32 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH
13:02:32 INFO : Device Mode Host Setup in Flash : change working directory to /home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
13:02:32 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
13:02:32 INFO : Device Mode Host Setup in Flash : current working directory is /home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
13:02:32 INFO : Device Mode Host Setup in Flash : exec_command [host]:
13:02:33 INFO : Device Mode Host Setup in Flash : **********************
13:02:33 INFO : Device Mode Host Setup in Flash : #!/bin/bash
13:02:33 INFO : Device Mode Host Setup in Flash : set -e
13:02:33 INFO : Device Mode Host Setup in Flash : function safe_apt_install {
13:02:33 INFO : Device Mode Host Setup in Flash : echo "*begin $1, $2"
13:02:33 INFO : Device Mode Host Setup in Flash : tmp_log=/tmp/jetpack_dpkg_log.txt
13:02:33 INFO : Device Mode Host Setup in Flash : sudo rm -f $tmp_log
13:02:33 INFO : Device Mode Host Setup in Flash : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
13:02:33 INFO : Device Mode Host Setup in Flash : while [ ${CMD_STATUS} -ne 0 ]; do
13:02:33 INFO : Device Mode Host Setup in Flash : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
13:02:33 INFO : Device Mode Host Setup in Flash : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
13:02:33 INFO : Device Mode Host Setup in Flash : else
13:02:33 INFO : Device Mode Host Setup in Flash : echo "Unhandled error when running $1"; exit 1
13:02:33 INFO : Device Mode Host Setup in Flash : fi
13:02:33 INFO : Device Mode Host Setup in Flash : done
13:02:33 INFO : Device Mode Host Setup in Flash : }
13:02:33 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk '/default via/ {print $5; exit}')
13:02:33 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == '' ]]; then
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'Can not found route default $eth_port_name, device mode setup failed!'
13:02:33 INFO : Device Mode Host Setup in Flash : exit 0
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'Found route default' $eth_port_name', setting up device mode'
13:02:33 INFO : Device Mode Host Setup in Flash : setup_t='192.168.55.0/24'
13:02:33 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
13:02:33 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
13:02:33 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
13:02:33 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
13:02:33 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
13:02:33 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == *'Got answer'* ]]; then
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS 8.8.8.8!'
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'Default google DNS is not working, trying to find a valid server in local host settings!'
13:02:33 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep 'DNS' | grep -o '[^:]*$')
13:02:33 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
13:02:33 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
13:02:33 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == *'Got answer'* ]]; then
13:02:33 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
13:02:33 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS' $dns'!'
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'Can not found a valid DNS server, device mode setup failed!'
13:02:33 INFO : Device Mode Host Setup in Flash : echo 'If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.'
13:02:33 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH.sh
13:02:33 INFO : Device Mode Host Setup in Flash : Found route default enp0s25, setting up device mode
13:02:33 INFO : Device Mode Host Setup in Flash : [host] [sudo] password for rishabh:
13:02:33 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
13:02:33 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 8.8.8.8!
13:02:33 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
13:02:33 INFO : Device Mode Host Setup in Flash : [ 8.00 KB used. Disk Avail: 350.01 GB ]
13:02:33 INFO : Device Mode Host Setup in Flash : [ NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH Install took 0s ]
13:02:33 INFO : Device Mode Host Setup in Flash : command finished successfully
13:02:33 INFO : install 'Device Mode Host Setup in Flash' success
13:02:33 INFO : Start to install 'Flash Jetson TX2'
13:02:33 DEBUG : Flash Jetson TX2 : running command < cd '/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' -L='/home/rishabh/.nvsdkm/logs/JetPack_4.2_Linux' -p='9343' -t='P3310' -e='undefined' >
13:02:33 INFO : Flash Jetson TX2 : [ Disk Avail:350.01 GB ]
13:02:33 INFO : Flash Jetson TX2 : Using GenericInstaller to Install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP
13:02:33 INFO : Flash Jetson TX2 : change working directory to /home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra
13:02:33 INFO : Flash Jetson TX2 : [ Component Install Started ]
13:02:33 INFO : Flash Jetson TX2 : current working directory is /home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra
13:02:33 INFO : Flash Jetson TX2 : exec_command [target]:
13:02:33 INFO : Flash Jetson TX2 : **********************
13:02:33 INFO : Flash Jetson TX2 : #!/bin/bash
13:02:33 INFO : Flash Jetson TX2 : set -e
13:02:33 INFO : Flash Jetson TX2 : function safe_apt_install {
13:02:33 INFO : Flash Jetson TX2 : echo "*begin $1, $2"
13:02:33 INFO : Flash Jetson TX2 : tmp_log=/tmp/jetpack_dpkg_log.txt
13:02:33 INFO : Flash Jetson TX2 : sudo rm -f $tmp_log
13:02:33 INFO : Flash Jetson TX2 : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
13:02:33 INFO : Flash Jetson TX2 : while [ ${CMD_STATUS} -ne 0 ]; do
13:02:33 INFO : Flash Jetson TX2 : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
13:02:33 INFO : Flash Jetson TX2 : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
13:02:33 INFO : Flash Jetson TX2 : else
13:02:33 INFO : Flash Jetson TX2 : echo "Unhandled error when running $1"; exit 1
13:02:33 INFO : Flash Jetson TX2 : fi
13:02:33 INFO : Flash Jetson TX2 : done
13:02:33 INFO : Flash Jetson TX2 : }
13:02:33 INFO : Flash Jetson TX2 : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
13:02:33 INFO : Flash Jetson TX2 : sudo reboot forced-recovery
13:02:33 INFO : Flash Jetson TX2 : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh"
13:04:43 ERROR : Flash Jetson TX2 : lost connection
13:06:54 INFO : Flash Jetson TX2 : exit status 255
13:06:54 WARNING : Flash Jetson TX2 : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh" finished with error, but ignored
13:06:54 INFO : Flash Jetson TX2 : exec_command: sleep 20
13:07:14 INFO : Flash Jetson TX2 : exec_command: sudo ./flash.sh jetson-tx2 mmcblk0p1
13:07:14 INFO : Flash Jetson TX2 : ###############################################################################
13:07:14 INFO : Flash Jetson TX2 : # L4T BSP Information:
13:07:14 INFO : Flash Jetson TX2 : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
13:07:14 INFO : Flash Jetson TX2 : # DATE: Wed Mar 13 07:41:08 UTC 2019
13:07:14 INFO : Flash Jetson TX2 : # Target Board Information:
13:07:14 INFO : Flash Jetson TX2 : # Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
13:07:14 INFO : Flash Jetson TX2 : # OpMode: production, Boot Authentication: NS,
13:07:14 INFO : Flash Jetson TX2 : ./tegraflash.py --chip 0x18 --applet "/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
13:07:14 ERROR : Flash Jetson TX2 : /usr/bin/env: ‘python’
13:07:14 ERROR : Flash Jetson TX2 : : No such file or directory
13:07:14 INFO : Flash Jetson TX2 : Reading board information failed.
13:07:14 INFO : Flash Jetson TX2 : exit status 1
13:07:14 INFO : Flash Jetson TX2 : [ Component Install Finished with Error ]
13:07:14 ERROR : Flash Jetson TX2 : NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
13:07:14 INFO : Flash Jetson TX2 : [ 4.00 KB used. Disk Avail: 350.01 GB ]
13:07:14 INFO : Flash Jetson TX2 : [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 4m42s ]
13:07:14 INFO : Flash Jetson TX2 : command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
13:07:14 ERROR : Flash Jetson TX2 : command terminated with error
13:07:14 ERROR : install 'Flash Jetson TX2' failure, command < cd '/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' -L='/home/rishabh/.nvsdkm/logs/JetPack_4.2_Linux' -p='9343' -t='P3310' -e='undefined' > terminated with error
13:07:14 INFO : install 'Device Mode Host Setup in Target SDK' Skipped
13:07:14 INFO : install 'DateTime Target Setup' Skipped
13:07:14 INFO : install 'CUDA Toolkit for L4T' Skipped
13:07:14 INFO : install 'cuDNN on Target' Skipped
13:07:14 INFO : install 'TensorRT on Target' Skipped
13:07:14 INFO : install 'OpenCV on Target' Skipped
13:07:14 INFO : install 'VisionWorks on Target' Skipped
13:07:14 INFO : install 'Multimedia API' Skipped
13:07:15 INFO : All done!
