Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Dear @qichen.ou,
Could you check how much time it is waiting before throwing the error on console. May be you could check increasing n_Timeout = 60 * 30 or 60 * 60 in WaitOnImageGeneration()/AdbServerManager() in DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x_py/bootburn_lib.py
HI @SivaRamaKrishnaNV , I solved, something wrong with USB port. I can enter recovery mode(lsusb get “Bus 003 Device 105: ID 0955:7019 NVidia Corp.”),but tegrarcm_v2 Cannot communicate with usb(error: USB communication failed.Check if device is in recovery).I switched to a newly installed ubuntu computer, the problem was solved, thanks a lot
Hi @qichen.ou thanks. so, when drive os 5.2 install successly, cuda 10.2, cudnn and tensorrt6.3 will be installed into agx?
I do not install SW, just install driver os. Are you same?
