If you donāt mind: excellent. Find below the cdl-log and the UART-log.
Please mind that I 1) entered miniconsole 2) flashed using the vendors tool. 3) rebooted (RCM). log01.txt (11.5 KB) log02.txt (48.7 KB)
Just a reminder that. I totally didnāt see any flash successfully log from your so far.
You have to learn how to tell whether a board got flashed or not⦠A successful flash requires to take about 15 minsā¦
If you hit error right after flash command, it wonāt be a successful oneā¦
Sorry for the confusion. I see now that that was a poor choice of words. I should have written ā2) initiated flashing using the vendors tool.ā. I failed after a few seconds, so no flash happened.
First time I attempted to flash using the vendors tool, I had not enabled miniconsole. So once I realized flash failed, I enable miniconsole and repeated the attempt. Thatās why there might be different timestamps.
If you saw the host side error log is USB timeout with sending bct_br, then it is as my previous comment. You need to disable the usb auto-suspend on your host PC.
Thank you for clarifying.
Iāve sent an email to the vendor earlier. I will report back to you if/once they contacted me.
Thank you once again for your time.
Brief update: I got support from the vendor. They did not manage to flash the board neither (using remote access to the host). Also strange: the board does not leave RCM. A new board one is on the wayā¦
I finally managed to flash. Here are the key-issues:
Ubuntu 18.04 does not seem to be compatible. Ubuntu 20.04 worked.
The command lsusb returns always āNvidia Corp.ā, as long as the board is plugged in (USB) and powered on. lsusb does not show whether the board is in recovery mode or not.
Hopefully, this saves other developers some troubles.
Both my boards had the issue, that they left me with the impression that they cannot leave the recovery mode - because lsusb always returs the āNvidia Corpā.
The support from the vendor, who remote controlled the ubuntu host, experienced the same issue - and initiated the exchange of the board.
Actually, I deal with lots kind of flash problem everyday. I always see some users give another post from somewhere else and said āhey, there is similar postā. But turned out they are not same issue at all.
For example, the whole error logs you shared in these 37 comments in this topic does not give āprobing the target board failed.ā error.
The post you think is same issue does not provide full log at all. His case is also based on VM. A VM means a unstable connection. I donāt know if you still used 18.04 VM or not. You said you are not using VM, then I trusted you.
Also, the post you shared may not be using ConnectTech carrier boardā¦
Since this issue is on custom board, maybe the vendor should review if any problem on their design. A recovery mode is a pure hardware event. When the board is in recovery mode, there is no software running on the board itself.
You are certainly right: the post I linked to is not a perfect fit. However, we both got [ 0.0805 ] ERROR: failed to read rcm_state. when the flash procedure starts. Switching to Ubuntu 20.04 solved the problem in both our cases.
Neither me nor the support from the vendor realized this error [ 0.0805 ] ERROR: failed to read rcm_state at the beginning of the log, because there are indication for USB-timeout further down in the log. We focused on (and failed) troubleshooting only the most recent errors, and eventually replaced the board.
I switched from VM to ābare metalā (Ubuntu 18.04) straight after you recommmended to do so ((see my post 01.10.23). Only yesterday, I switched from Ubuntu 18.04 to 20.04.
I already sent an email to the vendor support. I assume they will come back to me with more questions, if they want to dive into it.
This actually does not matter. Even the successful flash log may have this print.
Unless you didnāt see it in successful flash log, I donāt think it is the cause hereā¦
JetPack/SDKM works from more releases than what can be used. The particular L4T release being flashed, and the hardware being flashed, will limit the host PC release to a subset of what JetPack/SDKM works with. In the case of Orin Ubuntu 18.04 should work, but 20.04 is recommended. In all cases, regardless of what is being flashed, a VM tends to get in the way. VMs need to correctly handle USB passthrough even if there is a disconnect and reconnect, and this quite often fails. VMs are a major point of USB failure during flash.
