Hi NVIDIA team,
I am experiencing a flashing failure with a newer Jetson Orin Nano 8GB production module on our custom carrier board.
Our older 2024 units could be flashed successfully using the original vendor BSP. However, this newer module consistently resets during RCM SDRAM initialization, and the flashing process eventually fails with a USB timeout.
I applied the DRAM PCN package t234-dram-package-36.4.3_2026-08-27.tbz2, but the failure remains at the same SDRAM initialization stage.
- Module information
The module label, top/bottom photos, and chip marking photos are attached.
Module: Jetson Orin Nano 8GB commercial production module
Module P-number: P3767-0003
Ordering P/N: 900-13767-0030-000
Serial number: 1422126005657
Manufacturing date indicated by S/N: 2026 week 21
Country of manufacture: China
Board ID: 3767
FAB/version: 301
SKU: 0003
Revision: M.1
Corresponding 699-level information: 699-13767-0003-301 M.1
SoC: t234-A01-1-Silicon (0x12347), Prod
Chip SKU: D5
SoC marking: TE960M-A1
Additional SoC marking: B KR 2613A1
Raw RAMCODE: 3
Memory size: 8 GiB
QSPI flash: Macronix 64MB
ECID:
0x80012344705E03108C00000017FF8240
Software environment and flashing command
I am using a vendor BSP based on:
JetPack 6.2
L4T 36.4.3
The target rootfs is on an external NVMe drive. The complete flashing command is:
sudo ADDITIONAL_DTB_OVERLAY_OPT=“BootOrderNvme.dtbo,” \
./tools/kernel_flash/l4t_initrd_flash.sh \
–external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml \
-p “-c bootloader/generic/cfg/flash_t234_qspi.xml --no-systemimg” \
–network usb0 \
jetson-orin-nano-devkit nvme0n1p1
The module is correctly detected in recovery mode:
0955:7523 NVIDIA Corp. APX
First flashing attempt without the DRAM PCN
For the first attempt, I used the original vendor BSP without the additional DRAM PCN package.
The UART log shows:
MB1 version: 1.4.0.2
RAM_CODE: 0x4000431
The module loads the MEM-BCT but then resets around the following stage:
Task: SDRAM init
MSS CAR: Init PLLM
MSS CAR: Init PLLHUB
The host-side flashing log eventually reports:
Sending bct_mem
Sending blob
ERROR: might be timeout in USB write.
Error: Return value 3
Attachments for this attempt:
flash.txt: complete host-side flashing log
debug1.txt: complete UART log before applying the PCN -
Second flashing attempt after applying the DRAM PCN
I then applied the following package from the NVIDIA Jetson PCN Center:
After applying the PCN, the UART log confirms that the updated boot components are being used:
MB1 version: 1.4.0.4-t234-54845784-e89ea9bc
RAM_CODE: 0x4000031
The MEM-BCT is downloaded successfully and passes its integrity checks:
MEM-BCT-0 header integrity check is success
MEM-BCT-0 binary integrity check is success
Binary MEM-BCT-0 loaded successfully
RAM_CODE 0x4000031
However, the module still resets at the same SDRAM initialization stage:
Task: SDRAM init
MemoryType: 4 MemBctRevision: 1
MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
MSS CAR: Init PLLM
Encryption: MTS: en, TX: en, VPR: en, GSC: en
The UART output then restarts or falls back to the older boot chain stored in QSPI, and flashing fails again.
Attachment for this attempt:
debug2.txt: complete UART log after applying the PCN
The failure occurs before the external NVMe/rootfs flashing stage, so it does not appear to be related to the NVMe device or the root filesystem. -
DRAM part number and PCN coverage questions
I noticed that the PCN rc03 parameter file:
tegra234-mb1-bct-p3767-0001-rc03-665mhz.dtsi
mentions the following DRAM part number in its parameter-file comments:
K3KL1L10GM-JUCT_lpddr5_8CH_1R_8GB_3200.par
However, the DRAM marking on my module appears to be:
K3KL1L10GM-JGCT
I am not assuming that this suffix difference is necessarily the root cause, but I would like NVIDIA to confirm whether these DRAM variants are intended to share the same MEM-BCT.
Could you please help confirm the following?
1.Does t234-dram-package-36.4.3_2026-08-27.tbz2 support the Jetson Orin Nano 8GB P3767-0003 with Chip SKU D5 and raw RAMCODE 3?
2.Does this PCN cover this specific module manufactured in 2026 week 21, with serial number 1422126005657?
3.Can K3KL1L10GM-JGCT safely use the rc03 MEM-BCT generated for K3KL1L10GM-JUCT, or is a different DRAM configuration required?
4.Is there another DRAM PCN, a newer boot firmware package, or a newer L4T release required for this exact module and DRAM batch?
flash.txt — host flashing log from the first attempt without the PCN
debug1.txt — UART log from the first attempt without the PCN
debug2.txt — UART log from the second attempt after applying the PCN
Module top-side photo
Module bottom-side photo
Module ordering P/N and serial-number label photo
SoC and DRAM marking photos
Thank you for your assistance.
261029_log_pictures.tar.gz (28.3 MB)
