Flashing image to Tx2 fails.
I follow this guide to export and import image on Jetson TX2.
Exporting and Importing is done successfully without any errors.
However, after flashing, I reboot the board and it hangs at the startup screen.
1 error message is shown: [FAILED] Failed to start NVIDIA specific script.
Other messages are OK.
So, what is the problem here?
Thanks,
Hi thaihq.56,
Which image are you using?
Please make sure your steps is the same with me:
<b>Backup</b>:
sudo ./flash -r -k APP -G backup.img jetson-tx2 mmcblk0p1
<b>Restore</b>:
copy backup.img.raw to bootloader/system.img
sudo ./flash -r -k APP jetson-tx2 mmcblk0p1
I use the backup.img as the guide at TX2 Cloning - Jetson TX2 - NVIDIA Developer Forums
not the backup.img.raw
Hi thaihq.56,
Please try copy backup.img.raw to /bootloader/system.img and restore again.
Both images should in theory work, but I am curious if the release the clone is from matches the release of JetPack which the clone is being restored to? So for example, if you cloned from an R32.1 TX2, was the restore to a unit which also has R32.1 already on it?
Hi linuxdev,
Yes, suggest use the same release build.
Clone image from r32.1 then restore image to r32.1, the same JetPack release build.
