Flashing jetpack 4.6.3 does not display the desktop
I used the emmc development kit to burn jetpack4.6.3 version. But the log is displayed during the startup process, and finally there is no display on the black screen. I used the serial port connection to print the log as follows.
1.txt (134.1 KB)
is the situation also the same with the latest JetPack 5.1.1?
No, I started using jetpack5.1.1, and now I am burning jetpack4.6.3
can you put what you get with the following command here?
cat /var/log/Xorg.0.log
Sorry, it’s not available now. I can’t enter the desktop after burning jetpack4.6.3 repeatedly, but when I burn back jetpack5.1 and burn 4.6.3 it can.
can you login to the device with serial connection or SSH?
You mean you can get GUI to work with 4.6.3 if you flash 5.1.1 at first, and then 4.6.3?
But it does not work without 5.1.1 being pre-flashed?
I can log in from SSH or serial port.
At the beginning, I refreshed from jetpack5.1.1 to 4.6.3 and couldn’t enter the desktop, and I burned 4.6.3 repeatedly and couldn’t enter the desktop. Later, I burned jetpack5.1 to enter the desktop, and then burned 4.6.3 to enter the desktop.
So you think it’s fixed now?
I think it’s just some random glitches that can be fixed by re-flashing.
Yes, you can now access the desktop normally.
