FLASHING JETPACK 5.1.1 to new AGX ORIN DEVELOPER KIT
We have agx orin developer kit 64 gb. We tried to flash jetpack 5.1.1 over linux terminal. Unfortunately, we could not do it. Flash ended with this below
Waiting for device to expose ssh …Error: ipv6: address already assigned.
Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 75
max_index=74
writing item=59, 1:3:primary_gpt, 512, 19968, gpt_primary_1_3.bin, 16896, fixed–0, 660bff764e9cde35cf2745bf4a3be5d8249ee774
Writing primary_gpt partition with gpt_primary_1_3.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/internal/gpt_primary_1_3.bin of=/dev/mmcblk0 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0817188 s, 207 kB/s
Writing primary_gpt partition done
Error: Invalid argument during seek for read on /dev/mmcblk0
[ 5]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
  • the xml indicates the gpt is larger than the device storage
  • the xml might be invalid
  • the device might have a problem.
    Please make correction.
    Flash failure
    Cleaning up…
    We have applied a patch in p3701.conf.common. Still we are facing this difficulty. We are using below command to flash.
    sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1
    We tried this same command and flashed the jetpack 6. Is there any other way to flash.
    Looking forward to your response.
    Thank you.
    Regards,
    Karthick
Hi Karthick,
Since you mentioned that the same command successfully flashed JetPack 6, is there a specific reason you need to use JetPack 5.1.1, such as a dependency on a third-party driver or application?
If there is no strict JetPack 5.1.1 dependency, we recommend using JetPack 6.
If JetPack 5.1.1 is required, please verify that the patch was applied in both places. From the Linux_for_Tegra directory, run:
grep -n "update_local_cfgfile" p3701.conf.common flash.sh
The output should show:
  1. The update_local_cfgfile() function definition in p3701.conf.common.
  2. A call to the function in flash.sh after localcfgfile is generated:
update_local_cfgfile "${localcfgfile}"
If the call in flash.sh is missing, add it after localcfgfile is generated, and then retry your current flashing command.
Please also confirm that you applied the complete PCN210100 overlay for Jetson Linux R35.3.1 from the Jetson PCN Center, rather than only modifying p3701.conf.common.
Please share why JetPack 5.1.1 is required and the output of the grep command above.
Jetpack 5.1.1 is our customers requirement.
Patch resolved our issue.
Thank you for the support.
