I am using auvidea j140 with TX1.
I tried to install different jetpacks from 4.3 to 4.5.1. Over sdkmanager and over console.
But in all cases the flashing process stucks on “populating rootfs from /home/…/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/rootfs …”
sudo ./flash.sh jetson-tx1 mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-tx1, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet "/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.2201 ] Generating RCM messages
[ 0.2229 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.2256 ] RCM 0 is saved as rcm_0.rcm
[ 0.2620 ] RCM 1 is saved as rcm_1.rcm
[ 0.2644 ] List of rcm files are saved in rcm_list.xml
[ 0.2660 ]
[ 0.2660 ] Signing RCM messages
[ 0.3997 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.4026 ] Assuming zero filled SBK key
[ 0.4486 ]
[ 0.4487 ] Copying signature to RCM mesages
[ 0.4505 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.4561 ]
[ 0.4562 ] Boot Rom communication
[ 0.4574 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.4584 ] RCM version 0X210001
[ 0.5011 ] Boot Rom communication completed
[ 1.5078 ]
[ 1.5080 ] dump EEPROM info
[ 1.5116 ] tegrarcm --oem platformdetails eeprom /home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/cvm.bin
[ 1.5142 ] Applet version 00.01.0000
[ 1.5310 ] Saved platform info in /home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/cvm.bin
[ 1.6110 ]
[ 1.6147 ] tegrarcm --reboot recovery
[ 1.6175 ] Applet version 00.01.0000
[ 1.6359 ]
Board ID(2180) version(100)
copying bctfile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/BCT/P2180_A00_LP4_DSC_204Mhz.cfg)... done.
copying bootloader(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb to rootfs... done.
Making Boot image... done.
copying bcffile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/cfg/board_config_p2597-devkit.xml)... done.
Existing sosfile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb)... done.
Copying nv_boot_control.conf to rootfs
Making system.img...
populating rootfs from /home/../nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX1/Linux_for_Tegra/rootfs ...
