Hi NVIDIA team,
I’m flashing the eMMC on a Jetson AGX Orin devkit via USB 3.0 using l4t_initrd_flash.sh. The main issue I’m facing is that the QSPI flashing step intermittently fails. The total time for building the image + flashing is about 11 minutes 28 seconds.
Here are the commands I’m using:
Full rebuild + flash (rootfs + QSPI):
bash
time sudo ADDITIONAL_DTB_OVERLAY="BootOrderEmmc.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 jetson-agx-orin-devkit-super internal
Flash QSPI only:
bash
sudo ADDITIONAL_DTB_OVERLAY="BootOrderEmmc.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh -p "-c bootloader/generic/cfg/flash_t234_qspi.xml --no-systemimg" --network usb0 jetson-agx-orin-devkit-super mmcblk0p1
Flash rootfs + QSPI without rebuilding:
bash
time sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 jetson-agx-orin-devkit mmcblk0p1
My questions:
What are the common causes of intermittent QSPI flashing failures on AGX Orin when using
l4t_initrd_flash.shvia USB 3.0? Is this a known issue? -
Does the
BootOrderEmmc.dtbooverlay affect QSPI flashing stability? Is it required when flashing to eMMC, or only for specific boot order configurations? -
I notice some commands use
jetson-agx-orin-devkit-superand others usejetson-agx-orin-devkit. Could this inconsistency cause the QSPI flashing failure? -
Are there any recommended optimizations or workarounds to make QSPI flashing more reliable (e.g., different USB port, cable, host controller, or flashing parameters)?
Is the ~11.5 minute total time normal, and does QSPI failure significantly affect it?
Any guidance would be appreciated. Thanks!
initrd_flash.txt (309.6 KB)
