When trying to use SDK Manager 1.4.0.7362 on an Ubuntu 16.06 physical (not virtual) host machine I encounter the error:
13:59:01 INFO: Flash Jetson TX2: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 1s ]
13:59:01 ERROR: Flash Jetson TX2: [error]: : [exec_command]: /bin/bash -c sudo ./flash.sh jetson-tx2 mmcblk0p1; [error]:
13:59:01 ERROR: Flash Jetson TX2: command terminated with error
13:59:01 SUMMARY: Flash Jetson TX2: Installation failed.
The full logs of the install are attached. SDKM_logs_2021-01-06_13-52-44.zip (2.1 MB)
I need to use either Jetpack 3.3.1 or 3.3.2 because I need L4T 28.3. You can read about my issues installing 3.3.2 here.
