Hi!
I wonder if there is an option to make the jetson visible as mass storage device from the recovery mode? It will be very helpful for me to flash the jetson using the dd command
Hi!
hello shlomi.39sd,
may I have more details about why not using flash script to flash devices. thanks
FYI, long ago one could use the flash software not only for specific partitions, but also via offset. However, this still was not bulk storage, and dd would not have worked even then. I can understand the desire to use dd, but unless recovery mode were modified (which is probably not practical), this cannot happen. Recovery mode is a custom USB device, not a standard USB device.
