it seems that you are using GUI interface;
less issues you might have occured if used the headless sdk interface;
However, try to install missed components again and it will likely to resolve at N’s attempt
As per suggestion, I have removed part of email address from the posts.
I retired multiple times, but the result is the same. Deep stream does not work.
Solution that worked for me,
- VMWare player with ubuntu 16.04
- Run the Sdkmanager
- At 99%, USB will get disconnected and it will ask to connect it back. Connect it to the virtual machine
- Complete the flashing
- Install the remaining packages.
Only problem is the Deep stream is not installed. Rest works fine.
