在L4T35.3.1,如何制作一个量产环境,能同时刷多个agx-orin, 在低版本中使用sudo ./nvmassflashgen.sh -r board 制作量产环境,在高版本中,哪个命令式制作量产环境的?
請參考Linux_for_Tegra/tools/kernel_flash/README_initrd_flash.txt
裡的Workflow 7
Workflow 7: Initrd Massflash
Initrd Massflash works with workflow 3,4,5. Initrd massflash also requires you to do the massflash
in two steps.
First, generate massflash package using options --no-flash and --massflash <x> and --network usb0
Where <x> is the highest possible number of devices to be flashed concurrently.
Both online mode and offline mode are supported (Details can be seen in workflow 2).
In the example below, we use offline mode to create a flashing environment that is
capable of flashing 5 devices concurrently.
$ sudo BOARDID=<BOARDID> FAB=<FAB> BOARDSKU=<BOARDSKU> BOARDREV=<BOARDREV>
./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 5 --network usb0 jetson-xavier-nx-devkit-emmc mmcblk0p1
(For the value of BOARDID, FAB, BOARDSKU and BOARDREV, please refer to the table at the bottom of this file.)
Second,
- Connect all 5 Jetson devices to the flashing hosts.
(Make sure all devices are in exactly the same hardware revision similar to the requirement in
README_Massflash.txt )
- Put all of connected Jetsons into RCM mode.
- Run:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5 --network usb0
(Optionally add --showlogs to show all of the log)
Note:
the actual number of connected devices can be less than the maximum number
of devices the package can support.
Tips:
- The tool also provides the --keep option to keep the flash
environment, and the --reuse options to reuse the flash environment to make
massflash run faster:
Massflash the first time.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5 --network usb0 --keep
Massflash the second time.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5 --network usb0 --reuse
- Use ionice to make the flash process the highest I/O priority in the system.
$ sudo ionice -c 1 -n 0 ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 5
比方說
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash <x> --network usb0 jetson-agx-orin-devkit mmcblk0p1
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash <x> --network usb0
另外:agx orin 32g,是不是启动比较慢,能修改bios配置,使其系统快速启动吗?
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Kernel/BootTimeOptimzation.html
可以參考這裡
但如果是和原本不同問題的話麻煩發新的topic
