Here I get the error Flash complete with failures. I am attaching the log files. To my understanding it is something related to ssh but I can’t figure out if its because of wrong procedure or something wrong with my network settings. flash_1-4_1_20250320-133528.log (7.2 KB) flash_1-12_0_20250320-133528.log (7.1 KB)
Hello David,
Thank you for your reply. I had already disabled the firewall on my Ubuntu. I have NVMe SSD on both.
I ran the whole procedure again just after confirming the status of firewall but I am getting the same error. Is there any other checks that you want me to run. Also it says to install Secureboot package but I can’t find it for Jetson Linux 36.4.3
I think I have figured it out. One of the jetsons was a fused board which made it ask for a secure boot package. When I created a mass flash for only 1 and flashed the one that was not fused. It worked. Conversely when I tried to reuse the environment for flashing the fused one it failed.
Also if I manually flash it without any dependencies I can’t install TensorRT on the fused board is there any command I can do to ‘unfuse’ it?
