I need to flash many Jetsons with the same image and wondering if anyone knows how to do so, simultaneously, from a single host.
TIA
TIA
I’m not sure if it’s possible to flash them exactly at the same time but it should be doable to connect multiple Jetsons to one PC and flash them in a row one after another.
You can tell the flash script not to recreate the rootfs so it will use the existing image.
I would bet for non-serialized flashes the nvflash would need to be modified. It would probably be a worthwhile modification though if someone had a build farm and serialized install was too slow.
