Flashing new kernel not updating defconfig
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I followed the path to recompile kernel as per below link.
In step of doing menuconfig I am enabling the PPS config parameters. I follow the remaining steps and also the corrections for step 12.b
I am able to flash with bootburn but when i check after, the parameters are still unset like below
nvidia@tegra-ubuntu:~$ gunzip < /proc/config.gz | grep CONFIG_PPS
CONFIG_PPS=y
CONFIG_PPS_DEBUG is not set
CONFIG_PPS_CLIENT_KTIMER is not set
CONFIG_PPS_CLIENT_LDISC is not set
CONFIG_PPS_CLIENT_GPIO is not set
Kindly advice how to enable them.
Thanks!!
Jishnu
Dear @jishnuw,
Does this issue still need support?
Hi @SivaRamaKrishnaNV
I hacked it this time by editing all defconfigs. Not an ideal solution. If I missed a step or two pls do share, else we can close this topic until I face something similar again.
Thanks!!
Jishnu
Dear @jishnuw,
If possible, could you share those changes for reference. Thanks
When I say I hacked, after doing menuconfig and setting the required config to (*) We follow the steps ahead, But on flashing I was seeing the CONFIG value still as n. SO what I then did was grepped for all occurrences and set it to yes and re tried flashing. Not the best way to do it.
Currently I don’t have the exact changes since we moved ahead from this state.
Thanks!!
Jishnu
