Flashing NVMe stuck on Waiting for USB storage device flashpkg
I am trying to use the official docker image to flash the NVME on my Xavier NX using a Ubuntu host. In theory, everything works great, but in practice, things are getting a bit difficult. The flashing process gets stuck on the Waiting for USB storage device flashpkg step.
I have identified the root cause but am unable to find a solution. The problem is the that the initrd-flash script (of the yocto distribution I use) uses udevadm to identify the model and vendor of a candidate block device. Since udev, however, doesn’t run inside the docker container based on the nvidia image, the script doesn’t work in this way.
Are there any ideas out there on how to solve this problem?
Thank you very much in advance,
Marcus
If you have a Ubuntu host, you could install sdk manager directly.
What’s your ubuntu os version?
If your ubuntu version not compatible with sdk manager, you could install bsp and rootfs directly and flash.
