I am trying to flash my Orin NX through a docker container. All of the steps that I use to set it up are working without a docker container. But when I execute them within a docker container it gets stuck on “Waiting for target to boot up…”
I am using these steps for flashing: Quick Start — Jetson Linux Developer Guide documentation
Here are the logs: Flashlog (213.6 KB)
I run the docker container with the following command: sudo docker run -v /dev/bus/usb/:/dev/bus/usb/ --privileged -it flash_test
Ive tried to format the SSD either with and without empty ext4 partition.
I thought maybe it is not detecting my Jetson due to container permissions, but when I check lsusb I can see the device after the command fails. Also my laptop is able to see the SSD through the Jetson. I would assume its a docker setting but what could it be…
Hereby the Jetson log. It seems it booted up way before the timeout hit. So I think its a permission thing. But I cant figure out what. Could you try the above dockerfile and see if it works for you?
Ive found the solution
If you do not specify the --network usb0 it will work without issues. sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \ -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \ --showlogs --network usb0 p3509-a02+p3767-0000 internal
I checked the l4t internal script and it seems external mode somehow doesnt properly work when its specified in a docker container.
