I made my custom board based on Xavier-NX devkit. (SSD : NVME)
I flashed Xavier NX with jetson-xavier-nx-devkit-emmc.conf (Jetpack 4.6/4.7/5.1.2)
Now, I tried to use Jetson Orin NX on the board.
At first I tried to flash with jetson-orin-nano-devkit.conf. But, I failed.
I found in the forum that p3509-a02+p3767-0000.conf is recommended to use for xavier nx devkit board.
I tried to flash again with p3509-a02+p3767-0000.conf and flashed successfully.
But, there was another problem.
I could not detect jetson orin through usb. (my board is headless and I must set up with usb at first)
I tried a lot cases and find out one solution.
I modified dtsi file (tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi).
I modified spi2_cs0_pcc3.
(Devkit use this pin as CAM_MUX_SEL but I don’t use this pin and left it floating)
After modified the pin configuration, Orin NX was flashed well and detected well.
Why/How does the pin make the difference?
Is it a right solution?
I’m a ted’s coworker.
Please refer to the Board design below
USB_VBUS_det (GPIO00): It changes from High to Low at USB_VBUS input.
USB0 : USB_N, USB_P (GPIO109, GPIO111)
→ GPIO06 : Pull-up - Host PC can detect Jetson Orin NX via USB0.
Pull-down or none - Host PC cannot detect Jetson Orin NX vis USB0.
I don’t really see anything helpful from your comment… You just shared what Ted already told again with no extra info.
Your team does not provide a valid software log that can prove this behavior really happened on your side.
What you posted does not meet what you described.
I still don’t know whether GPIO06 has anything to do on your board. You better reviewing your hardware schematic by yourself but not providing same info to me again and again.
