Hello everyone,
I’ve purchased the Jetson Nano Module after some development on a Jetson Nano Development Kit.
I would like to flash OS to the eMMC on my new Jetson Nano Module and deploy my code.
Is there any guide for this?
Hello everyone,
Hi carolyuu,
Thank you for your reply.
I’ve read the doc and found out that I have a A02 carrier so I can’t flash the os using the sdk manager.
Is there another way?
If I have to purchase other carrier, which carriers support flashing the os and how can I purshace one?
Thank you very much.
Hi lyon100,
Jetson ecosystem partners are already introducing new off the shelf carrier boards compatible with the production module, please check:
https://devtalk.nvidia.com/default/topic/1061275/jetson-nano/jetson-nano-module-available-now/post/5374344/#5374344
Hi lyon100,
Download the sdkmanager on your host ubuntu machine and following instruction to run sdkmanager, then reference link to flash and install with sdkmanager.
The “Target Hardware” select Jetson Nano (P3448-0020), this is for A02 Jetson-Nano bard.
Hi carolyuu,
I have A02 board (dev kit) so I took out the sdcard-module and inserted the emmc-module. To my understanding the A02 board does not suport flashing to the emmc-module, am I correct?
And by the way does it support running it?
