@SivaRamaKrishnaNV
Really thanks for your help
I would like to summarize the problem I encountered these days from one greener perspective , may the resolution will be useful for your side to provide some hints to the greener users like me .
Setup the minicom
you could download and install minicom directly use terminal
sudo apt-get install minicom
BUT here exists one important operation before use minicom to connect pegasus, you need to configure minicom let minicom could type in command line
sudo minicom -s
you need to configure the Hardware Flow Control and convert the value from Yes to No -
Power off your host and power one your host
this step make sure your host is clean -
Power on your target pegasus
connect your host and target per sudo minicom -D /dev/ttyUSB3, and you could see some alert -
Power off the target , and power on the target
type into the command lines
make sure you could see NVIDIA corp from lsusb
Do not restart the target pegasus
Restart the host make sure there does not exists any aurix connect
start the sdk manager to flash the target pegasus
