Hello all,
I’ve got problem with my Jestsons - I can’t flash file system to TX2. I am using Jetson TX2 with auvidea J90. I’ve downloaded Jetpack 3.3, replaced necessary files (from auvidea firmare), put my TX2 into recovery mode (command lsusb shows NVidia Corp), but the installer still says :
“error: probing the target board failed”
I’ve tried 2 diffrent Jestons and 2 different J90 boards, different USB ports (every time Jeston comes up as NVidida Corp) but every time i get the same error. Flashing OS to dev board Jetson worked just fine.
I’m using ubuntu 16.04 (not VM)
I’m connecting J90 with USB cable included to devKit.
I’ve tried to connect to board via UART0 - the MCU connects.
Can anyone help me?
