Flashing problems, might be related with a bad ssd
I have attached the log, trying to flash Jetpack to Orin NX, but I fall into this:
15:34:11 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:34:13 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:34:14 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:34:15 INFO: Flash Jetson Linux - flash: Waiting for target to boot-up…
15:34:16 INFO: Flash Jetson Linux - flash: Timeout
15:34:16 INFO: Flash Jetson Linux - flash: Cleaning up…
15:34:16 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
15:34:16 ERROR: Flash Jetson Linux - flash: command terminated with error
15:34:16 SUMMARY: DateTime Target Setup - target: Depends on failed component
I am not sure if it has to do with the fact that the SSD might not be good. After all, I bought a small sized one and not from the most trust worthy of brands.
Thanks in advance!
sdkm-2023-05-30-14-53-03.log (1.3 MB)
Hi imagidan,
What’s your carrier board for Orin NX?
Please provide the serial console log from the board.
The timeout issue from Step3 is always caused from boot up failed somewhere.
