Hello all,
A number of Jetson Orin NX 16GB/8GB and Jetson Orin Nano 8GB/4GB modules were programmed at the factory with the QSPI block protection bit enabled. This process has since been updated, and the factory no longer programs modules with the QSPI block protection bit enabled. If you encounter flashing issues while using flash.sh, your module may have this bit enabled. We recommend using l4t_initrd_flash.sh to flash these modules instead. For more information on flashing with l4t_initrd_flash.sh, refer to Flashing with Initrd.
