Hi, where to find the logs of flash.sh?
when you run the flash command, it would show flash logs on the console.
Oh, I didnt able to capture it during the time of flashing. Can I re-flash now? The jetson is on but no display even the USB hub connected to it is not working. I still see it in lsusb though. Here is the logs from the gtkterm connected through the host.
sudo minicom -D /dev/ttyUSB3 -8 -b 115200
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB3, 14:26:32
Press CTRL-A Z for help on special keys
[0000.501] I> Relocating BR-BCT
[0000.503] > DEVICE_PROD: device prod is not initialized.
[0000.528] E> I2C: slave not found in slaves.
[0000.529] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.530] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.531] E> I2C_0xae at 0x00000000 via instance 0.
[0000.532] E> eeprom: Failed to read I2C slave device
[0000.535] I> Failed to read CVB eepAC ...
[0000.613] I> Relocating OP-TEE dtb from: 0x6bfff1d0 to 0x70050000, size: 1008
[0000.614] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.615] I> [1] STA000
[0000.630] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.644] I> found decompressor handler: lz4
VA:0x526ff400
[0001.141] I> Setting EKB blob info to OPTEE dtb finished.
��I/TC: Non-secure external DT fouclk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initirs: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initianitialized
emc_early initialized
392 clocks registered
tialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
EE version: 3.16 (gcc ve��avfs_clk_platform initialized
��rsion 9.3.0��soctherm initialized
�� (��aotag initialized
��Bu��powergate initialized
��ildroot 2020.08)) #2 Thu Aug 11 03:23:20 UTC 2022 aarch64
I/TC: !
I/TC: WARNING: Please check https://optee.readthinitialized
strap initialized
��u��nvl initialized
��re/porting��emc initialized
emc_mrq initialized
��_guidelines.html
I�clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 rnitialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_d
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platfor��I/TC: Primary CPU switching to normal worlBase:0xc9400000 Size:0x00400000
[0001.810] I> 7) Base:0xc9000000 Size:0x00400000
[0001.814] I> 8) Base:0xc8000000 Size:0x000
[0001.823] I> 10) Base:0xca800000 Size:0x00800000
[0001.827] I> 11) Base:0x40000000 Size:0x00040000
[0001.832] I> 12) Base24) Base:0xcc000000 Size:0x02000000
[0001.890] I> 25) Base:0x40050000 Size:0x00002000
[0001.894] I> 26) Base:0x40040000 Size:00000
[0001.903] I> 28) Base:0xc8400000 Size:0x00200000
[0001.908] I> 29) Base:0xc8800000 Size:0x00400000
[0001.912] I> 30) 001.935] I> 35) Base:0xae000000 Size:0x01000000
[0001.939] I> 36) Base:0xa0000000 Size:0x0e000000
[0001.943] I> 37) Base:0xca0 Size:0x20000000
[0001.952] I> 39) Base:0xb0000000 Size:0x08000000
[0001.957] I> 40) Base:0x00000000 Size:0x00000000
[0001. I> 42) Base:0x00000000 Size:0x00000000
[0001.970] I> 43) Base:0x00000000 Size:0x00000000
[0001.975] I> 44) Base:0x00000000 Sx00000000
[0001.984] GIC-SPI Target CPU: 0
[0001.987] Interrupts Init done
[0001.990] calling constructors
[0001.992] initi0000]
[0001.999] initializing threads
[0002.002] initializing timers
[0002.005] creating bootstrap completion thread
[0002.40, MPIDR: 0x80000000
[0002.017] initializing platform
[0002.020] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.02@0xadf00000
[0002.032] I> gpio framework initialized
[0002.044] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpregister 'nvidia,tegra194-gpio-aon' driver
[0002.058] I> fixed regulator driver initialized
[0002.074] I> register 'maxim' po2.077] I> registered 'maxim,max20024' pmic
[0002.077] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.MMC_BOOT instance: 3
[0002.083] I> sdmmc-3 params source = boot args
[0002.086] W> No board IDs available
[0002.088] E> Failready initialized
[0002.096] I> sdmmc-3 params source = boot args
[0002.103] I> Found 20 partitions in SDMMC_BOOT (instance 3ance 3)
[0002.130] I> enabling 'vdd-hdmi-5v0' regulator
[0002.137] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.137] I>gured for 'vdd-1v0'
[0002.147] W> set volts not configured for 'vdd-1v8-hs'
[0002.147] I> retrieved tmds range from prod_list_hdmi_soc
[0002.153] E> invalid display type
[0002.159] E> invalid display type
[0002.160] E> cannot find any other nvdisp nodes
[0002.177] I> edid read success
[0002.189] I> edid read success
[0002.190] I> width = 640, height = 480, frequency = 25174825
[0002.190] I> width = 64> width = 640, height = 480, frequency = 25174825
[0002.195] I> width = 720, height = 480, frequency = 26973026
[0002.201] I>.206] I> width = 1280, height = 720, frequency = 74175824
[0002.212] I> width = 1920, height = 1080, frequency = 148351648
[0026
[0002.223] I> width = 720, height = 576, frequency = 26973026
[0002.229] I> width = 1280, height = 720, frequency = 74175y = 148351648
[0002.240] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.251] I> hdmi_enable, starting HDMI sation complete
[0002.265] initializing target
[0002.266] calling apps_init()
[0002.266] starting app kernel_boot_app
[0002
Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
You could capture them after flash procedure has been done. Just copy and paste from terminal on your host PC to capture flash log.
Please enter force recovery mode and use flash.sh to re-flash your board.
in lsusb, it shows NVIDIA corp so I proceed with the flashing. Here is the log:
# L4T BSP Information:
# R35 , REVISION: 1.0
# Target Board Information:
# Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0150 ] Generating RCM messages
[ 0.0181 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0188 ] Header already present for /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0237 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0239 ] Assuming zero filled SBK key
[ 0.0257 ] tegrasign_v3.py --file /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0258 ] Assuming zero filled SBK key
[ 0.0299 ] Warning: pub_key.key is not found
[ 0.0312 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0360 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0394 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0399 ] RCM 0 is saved as rcm_0.rcm
[ 0.0418 ] RCM 1 is saved as rcm_1.rcm
[ 0.0418 ] RCM 2 is saved as rcm_2.rcm
[ 0.0418 ] List of rcm files are saved in rcm_list.xml
[ 0.0418 ]
[ 0.0418 ] Signing RCM messages
[ 0.0442 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.0444 ] Assuming zero filled SBK key
[ 0.0474 ] Warning: pub_key.key is not found
[ 0.0468 ] Copying signature to RCM mesages
[ 0.0485 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0494 ] Boot Rom communication
[ 0.0511 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0516 ] RCM version 0X190001
[ 0.0524 ] Boot Rom communication completed
[ 2.0751 ] tegrarcm_v2 --isapplet
[ 2.0761 ] Applet version 01.00.0000
[ 2.0807 ] tegrarcm_v2 --ismb2
[ 2.0850 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[ 2.0861 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[ 2.0866 ] adding BCH for nvtboot_applet_t194_aligned.bin
[ 2.0914 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.0915 ] Assuming zero filled SBK key
[ 2.0927 ] Warning: pub_key.key is not found
[ 2.0939 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[ 2.0970 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.0975 ] Applet version 01.00.0000
[ 2.0995 ] Sending mb2
[ 2.0995 ] [................................................] 100%
[ 2.1179 ] tegrarcm_v2 --boot recovery
[ 2.1184 ] Applet version 01.00.0000
[ 3.1255 ] tegrarcm_v2 --isapplet
[ 3.1301 ] tegrarcm_v2 --ismb2
[ 3.1308 ] MB2 Applet version 01.00.0000
[ 3.1349 ] tegrarcm_v2 --ismb2
[ 3.1354 ] MB2 Applet version 01.00.0000
[ 3.1395 ] Retrieving board information
[ 3.1412 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.1419 ] MB2 Applet version 01.00.0000
[ 3.1462 ] Saved platform info in chip_info.bin
[ 3.1505 ] Chip minor revision: 2
[ 3.1506 ] Bootrom revision: 0xf
[ 3.1506 ] Ram code: 0x2
[ 3.1507 ] Chip sku: 0xd0
[ 3.1507 ] Chip Sample: non es
[ 3.1517 ] Retrieving EEPROM data
[ 3.1517 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.1527 ] MB2 Applet version 01.00.0000
[ 3.1571 ] Saved platform info in /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 3.1972 ] Rebooting to recovery mode
[ 3.1990 ] tegrarcm_v2 --ismb2
[ 3.1997 ] MB2 Applet version 01.00.0000
[ 3.2019 ] Rebooting to recovery mode
[ 3.2036 ] tegrarcm_v2 --reboot recovery
[ 3.2041 ] MB2 Applet version 01.00.0000
Board ID(2888) FAB(400) sku(0004) revision(K.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb ...
Copy /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
copying bctfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying dev_params_b(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-sdmmc.cfg)... done.
Existing bootloader(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0007 ] Generating signature
[ 0.0034 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0035 ] Assuming zero filled SBK key : not reading
[ 0.0031 ] Generating ratchet blob
[ 0.0048 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0054 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0060 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0060 ]
[ 0.0060 ] header_magic: 414e4452
[ 0.0220 ] tegrahost_v2 --chip 0x19 --align 1_boot_aligned.img
[ 0.0243 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot_aligned.img zerosbk
[ 0.0249 ] adding BCH for 1_boot_aligned.img
[ 0.5303 ] tegrasign_v3.py --key --list 1_boot_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.5305 ] Assuming zero filled SBK key : not reading
[ 0.5886 ] Warning: pub_key.key is not found
[ 0.5901 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_aligned_sigheader.img.encrypt 1_boot_aligned_sigheader.img.hash zerosbk
[ 0.8948 ] Signed file: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x281c000 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
36144 blocks
gzip: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
53066 blocks
Making Recovery image...
copying recdtbfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 7.0359e-05 s, 284 kB/s
Existing sosfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
Existing bpfdtbfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p2888-a04_lz4.dtb) reused.
Existing scefile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing apefile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing eksfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[ 0.0129 ] Generating signature
[ 0.0155 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0156 ] Assuming zero filled SBK key : not reading
[ 0.0152 ] Generating ratchet blob
[ 0.0170 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0176 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0178 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0179 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0179 ]
[ 0.0179 ] header_magic: d00dfeed
[ 0.0188 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 0.0212 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[ 0.0217 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 0.0295 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0297 ] Assuming zero filled SBK key : not reading
[ 0.0313 ] Warning: pub_key.key is not found
[ 0.0327 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[ 0.0364 ] Signed file: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x5bfbe to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making system.img...
Setting "FDT /boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb" successfully in the extlinux.conf...done.
populating rootfs from /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
generating sig file of Image ... /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign ./boot/Image kernel
version 1.0.0
[ 0.0118 ] Generating signature
[ 0.0141 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0143 ] Assuming zero filled SBK key : not reading
[ 0.0139 ] Generating ratchet blob
[ 0.0157 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0162 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0164 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0164 ]
[ 0.0165 ] header_magic: 4d5a0091
[ 0.0283 ] tegrahost_v2 --chip 0x19 --align 1_Image_aligned
[ 0.0296 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image_aligned zerosbk
[ 0.0301 ] adding BCH for 1_Image_aligned
[ 0.4326 ] tegrasign_v3.py --key --list 1_Image_aligned_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.4327 ] Assuming zero filled SBK key : not reading
[ 0.4786 ] Warning: pub_key.key is not found
[ 0.4792 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_aligned_sigheader.encrypt 1_Image_aligned_sigheader.hash zerosbk
[ 0.7307 ] Signed file: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x2019200 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/Image.sig
done.
generating sig file of kernel_tegra194-p2888-0001-p2822-0000.dtb ... /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign ./boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[ 0.0124 ] Generating signature
[ 0.0148 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0149 ] Assuming zero filled SBK key : not reading
[ 0.0145 ] Generating ratchet blob
[ 0.0162 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0168 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0170 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0170 ]
[ 0.0171 ] header_magic: d00dfeed
[ 0.0190 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 0.0202 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[ 0.0208 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 0.0281 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0282 ] Assuming zero filled SBK key : not reading
[ 0.0297 ] Warning: pub_key.key is not found
[ 0.0310 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[ 0.0345 ] Signed file: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb.sig
done.
generating sig file of initrd ... /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/initrd data
version 1.0.0
[ 0.0132 ] Generating signature
[ 0.0157 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0159 ] Assuming zero filled SBK key : not reading
[ 0.0156 ] header_magic: 1f8b0800
[ 0.0195 ] tegrahost_v2 --chip 0x19 --align 1_initrd_aligned
[ 0.0220 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd_aligned zerosbk
[ 0.0227 ] adding BCH for 1_initrd_aligned
[ 0.1257 ] tegrasign_v3.py --key --list 1_initrd_aligned_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.1258 ] Assuming zero filled SBK key : not reading
[ 0.1383 ] Warning: pub_key.key is not found
[ 0.1399 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_aligned_sigheader.encrypt 1_initrd_aligned_sigheader.hash zerosbk
[ 0.2010 ] Signed file: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x8019a3 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/initrd.sig
done.
generating sig file of extlinux.conf ... /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/extlinux/extlinux.conf data
version 1.0.0
[ 0.0169 ] Generating signature
[ 0.0196 ] tegrasign_v3.py --key --getmode mode.txt
[ 0.0198 ] Assuming zero filled SBK key : not reading
[ 0.0193 ] header_magic: 54494d45
[ 0.0211 ] tegrahost_v2 --chip 0x19 --align 1_extlinux_aligned.conf
[ 0.0225 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux_aligned.conf zerosbk
[ 0.0230 ] adding BCH for 1_extlinux_aligned.conf
[ 0.0262 ] tegrasign_v3.py --key --list 1_extlinux_aligned_sigheader.conf_list.xml --pubkeyhash pub_key.key
[ 0.0263 ] Assuming zero filled SBK key : not reading
[ 0.0273 ] Warning: pub_key.key is not found
[ 0.0285 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_aligned_sigheader.conf.encrypt 1_extlinux_aligned_sigheader.conf.hash zerosbk
[ 0.0294 ] Signed file: /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: chip 0x19: add 0x410 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/extlinux/extlinux.conf.sig
done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.111028 s, 604 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
done.
Existing flasher(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/L4TRootfsInfo.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2822-camera-dual-imx274-overlay.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2822-camera-e3331-overlay.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2822-camera-e3333-overlay.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2822-camera-imx185-overlay.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2822-camera-imx390-overlay.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2888-0005-overlay.dtbo) reused.
Existing overlay_dtb(/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-p2888-0001-p2822-0000-overlay.dtbo) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --overlay_dtb L4TConfiguration.dtbo,L4TRootfsInfo.dtbo,tegra194-p2822-camera-dual-imx274-overlay.dtbo,tegra194-p2822-camera-e3331-overlay.dtbo,tegra194-p2822-camera-e3333-overlay.dtbo,tegra194-p2822-camera-imx185-overlay.dtbo,tegra194-p2822-camera-imx390-overlay.dtbo,tegra194-p2888-0005-overlay.dtbo,tegra194-p2888-0001-p2822-0000-overlay.dtbo --bldtb tegra194-p2888-0001-p2822-0000.dtb --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg,tegra194-br-bct_b-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb" --secondary_gpt_backup --bct_backup --boot_chain A
saving flash command in /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0196 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0197 ] Assuming zero filled SBK key
[ 0.0020 ] Generating RCM messages
[ 0.0029 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0034 ] Header already present for mb1_t194_prod.bin
[ 0.0246 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0247 ] Assuming zero filled SBK key
[ 0.0264 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0265 ] Assuming zero filled SBK key
[ 0.0282 ] Warning: pub_key.key is not found
[ 0.0111 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0154 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0180 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0185 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0187 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0187 ]
[ 0.0208 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0214 ] RCM 0 is saved as rcm_0.rcm
[ 0.0237 ] RCM 1 is saved as rcm_1.rcm
[ 0.0237 ] RCM 2 is saved as rcm_2.rcm
[ 0.0237 ] List of rcm files are saved in rcm_list.xml
[ 0.0238 ] Signing RCM messages
[ 0.0434 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.0435 ] Assuming zero filled SBK key
[ 0.0464 ] Warning: pub_key.key is not found
[ 0.0286 ] Copying signature to RCM mesages
[ 0.0303 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0313 ] odmdata (to decode) = 152633344
[ 0.0313 ] Odmdata strings: PCIE_XBAR_4_1_0_1_2,UFS_x1_L1,NVHS_PCIE,enable-debug-console,enable-denver-wdt
[ 0.0313 ] Bpmp odmdata config: {'pcie-xbar-config': [0, 1, 'PCIE_XBAR_4_1_0_1_2'], 'pcie-c0-endpoint-enable': [1, 0, ''], 'pcie-c4-endpoint-enable': [1, 0, ''], 'ufs-config': [0, 1, 'UFS_x1_L1'], 'sata-enable': [1, 0, ''], 'nvhs-owner': [0, 1, 'PCIE'], 'pcie-c5-endpoint-enable': [1, 0, '']}
[ 0.0328 ] bpmp_dtb is compressed; decompressing...
[ 0.0328 ] lz4c -df tegra194-a02-bpmp-p2888-a04_lz4.dtb tegra194-a02-bpmp-p2888-a04_lz4_with_odm.dtb
[ 0.0356 ] tegra194-a02-bpmp-p2 : decoded 989312 bytes
[ 0.0356 ]
[ 0.1346 ] Re-compressing updated bpmp_dtb
[ 0.1346 ] lz4c -zf tegra194-a02-bpmp-p2888-a04_lz4_with_odm.dtb tegra194-a02-bpmp-p2888-a04_lz4.dtb
[ 0.1368 ] Compressed 989271 bytes into 86508 bytes ==> 8.74%
[ 0.1368 ]
[ 0.3310 ] Concatenating L4TConfiguration.dtbo,L4TRootfsInfo.dtbo,tegra194-p2822-camera-dual-imx274-overlay.dtbo,tegra194-p2822-camera-e3331-overlay.dtbo,tegra194-p2822-camera-e3333-overlay.dtbo,tegra194-p2822-camera-imx185-overlay.dtbo,tegra194-p2822-camera-imx390-overlay.dtbo,tegra194-p2888-0005-overlay.dtbo,tegra194-p2888-0001-p2822-0000-overlay.dtbo to tegra194-p2888-0001-p2822-0000_with_odm_overlay.dtb
[ 0.3315 ] Parsing partition layout
[ 0.3339 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.3356 ] Reading ramcode from backup chip_info.bin file
[ 0.3358 ] RAMCODE Read from Device: 2
[ 0.3358 ] Disable BPMP dtb trim, using default dtb
[ 0.3358 ]
[ 0.3358 ] Creating list of images to be signed
[ 0.3376 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.3383 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[ 0.3387 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[ 0.3388 ] MB1: Nvheader already present is mb1_b_t194_prod_aligned.bin
[ 0.3407 ] Header already present for mb1_b_t194_prod_aligned_sigheader.bin
[ 0.3408 ] adding BCH for spe_t194_aligned.bin
[ 0.3428 ] adding BCH for nvtboot_t194_aligned.bin
[ 0.3443 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 0.3469 ] adding BCH for spe_t194_aligned.bin
[ 0.3471 ] adding BCH for nvtboot_t194_aligned.bin
[ 0.3483 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 0.3509 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 0.3512 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 0.3577 ] adding BCH for nvdisp-init_aligned.bin
[ 0.4003 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 0.4359 ] adding BCH for tos-optee_t194_aligned.img
[ 0.4446 ] adding BCH for eks_aligned.img
[ 0.4548 ] adding BCH for bpmp-2_t194_aligned.bin
[ 0.4568 ] adding BCH for tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 0.4679 ] adding BCH for xusb_sil_rel_fw_aligned
[ 0.4693 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 0.4717 ] adding BCH for adsp-fw_aligned.bin
[ 0.4782 ] Header already present for warmboot_t194_prod_aligned.bin
[ 0.4827 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 0.4832 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 0.4893 ] adding BCH for nvdisp-init_aligned.bin
[ 0.5327 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 0.5688 ] adding BCH for tos-optee_t194_aligned.img
[ 0.5752 ] adding BCH for eks_aligned.img
[ 0.5852 ] adding BCH for bpmp-2_t194_aligned.bin
[ 0.5865 ] adding BCH for tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 0.5984 ] adding BCH for xusb_sil_rel_fw_aligned
[ 0.5995 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 0.6018 ] adding BCH for adsp-fw_aligned.bin
[ 0.6084 ] Header already present for warmboot_t194_prod_aligned.bin
[ 0.6134 ] Filling MB1 storage info
[ 0.6134 ] Parsing dev params for multi chains
[ 0.6134 ] Generating br-bct
[ 0.6156 ] Performing cfg overlay
[ 0.6156 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 0.6157 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg
[ 0.6476 ] Updating dev and MSS params in BR BCT
[ 0.6476 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 0.6872 ] Updating bl info
[ 0.6895 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 0.6909 ] Generating br-bct
[ 0.6927 ] Performing cfg overlay
[ 0.6927 ] ['/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg']
[ 0.6928 ] Updating dev and MSS params in BR BCT
[ 0.6928 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 0.7315 ] Updating bl info
[ 0.7337 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 0.7350 ] Generating BCT backup image
[ 0.7350 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 0.7358 ] 32768+0 records in
[ 0.7537 ] 32768+0 records out
[ 0.7537 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0176724 s, 1.9 MB/s
[ 0.7537 ]
[ 0.7537 ] Concatenating BCT for chain A to bct_backup.img
[ 0.7538 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 0.7548 ] 2888+0 records in
[ 0.7561 ] 2888+0 records out
[ 0.7561 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00104368 s, 2.8 MB/s
[ 0.7561 ]
[ 0.7561 ] Concatenating BCT for chain B to bct_backup.img
[ 0.7561 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 0.7568 ] 2888+0 records in
[ 0.7581 ] 2888+0 records out
[ 0.7581 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00105887 s, 2.7 MB/s
[ 0.7581 ]
[ 0.7581 ] Generating signatures
[ 0.7779 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.7780 ] Assuming zero filled SBK key
[ 0.8333 ] Warning: pub_key.key is not found
[ 0.8155 ] Parsing dev params for multi chains
[ 0.8155 ] Generating br-bct
[ 0.8174 ] Performing cfg overlay
[ 0.8174 ] ['/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg']
[ 0.8174 ] Updating dev and MSS params in BR BCT
[ 0.8174 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 0.8552 ] Updating bl info
[ 0.8574 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.8589 ] Updating smd info
[ 0.8608 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 0.8617 ] Updating Odmdata
[ 0.8636 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 0.8646 ] Signing BCT
[ 0.8646 ] Get Signed section of bct
[ 0.8663 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 0.8868 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.8869 ] Assuming zero filled SBK key
[ 0.8880 ] Warning: pub_key.key is not found
[ 0.8703 ] Updating BCT with signature
[ 0.8721 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 0.8729 ] Generating br-bct
[ 0.8745 ] Performing cfg overlay
[ 0.8745 ] ['/home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg']
[ 0.8745 ] Updating dev and MSS params in BR BCT
[ 0.8746 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 0.9119 ] Updating bl info
[ 0.9141 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.9157 ] Updating smd info
[ 0.9176 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 0.9186 ] Updating Odmdata
[ 0.9205 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 0.9214 ] Signing BCT
[ 0.9214 ] Get Signed section of bct
[ 0.9232 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 0.9436 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.9437 ] Assuming zero filled SBK key
[ 0.9449 ] Warning: pub_key.key is not found
[ 0.9271 ] Updating BCT with signature
[ 0.9289 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 0.9299 ] Generating BCT backup image
[ 0.9299 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 0.9306 ] 32768+0 records in
[ 0.9482 ] 32768+0 records out
[ 0.9482 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0172912 s, 1.9 MB/s
[ 0.9482 ]
[ 0.9482 ] Concatenating BCT for chain A to bct_backup.img
[ 0.9483 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 0.9492 ] 2888+0 records in
[ 0.9505 ] 2888+0 records out
[ 0.9505 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00102076 s, 2.8 MB/s
[ 0.9505 ]
[ 0.9505 ] Concatenating BCT for chain B to bct_backup.img
[ 0.9505 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 0.9514 ] 2888+0 records in
[ 0.9526 ] 2888+0 records out
[ 0.9526 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.000989501 s, 2.9 MB/s
[ 0.9526 ]
[ 0.9526 ] Generating coldboot mb1-bct
[ 0.9547 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 0.9554 ] MB1-BCT version: 0x1
[ 0.9557 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 0.9559 ] Added Platform Config 0 data with size :- 3168
[ 0.9568 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 0.9569 ] Added Platform Config 1 data with size :- 19640
[ 0.9631 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 0.9632 ] Added Platform Config 2 data with size :- 24
[ 0.9633 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 0.9634 ] File read failed
[ 0.9635 ] File read failed
[ 0.9635 ] Added Platform Config 4 data with size :- 348
[ 0.9636 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 0.9637 ] Added Platform Config 3 data with size :- 92
[ 0.9638 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 0.9639 ] Added Platform Config 5 data with size :- 68
[ 0.9640 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 0.9641 ] Added Platform Config 7 data with size :- 392
[ 0.9642 ]
[ 0.9642 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 0.9642 ] Added Platform Config 8 data with size :- 12
[ 0.9642 ]
[ 0.9642 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 0.9642 ] Added Platform Config 9 data with size :- 32
[ 0.9642 ]
[ 0.9642 ] Updating mb1-bct with firmware information
[ 0.9660 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.9669 ] Updating mb1-bct with storage information
[ 0.9687 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.9697 ] Updating mb1-bct with ratchet information
[ 0.9715 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.9721 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.9722 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.9723 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.9723 ]
[ 0.9743 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.9758 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.9764 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.9967 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 0.9968 ] Assuming zero filled SBK key
[ 0.9979 ] Warning: pub_key.key is not found
[ 0.9820 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.9831 ] Generating recovery mb1-bct
[ 0.9849 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 0.9857 ] MB1-BCT version: 0x1
[ 0.9860 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 0.9862 ] Added Platform Config 0 data with size :- 3168
[ 0.9869 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 0.9870 ] Added Platform Config 1 data with size :- 19640
[ 0.9930 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 0.9931 ] Added Platform Config 2 data with size :- 24
[ 0.9932 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 0.9933 ] File read failed
[ 0.9934 ] File read failed
[ 0.9934 ] Added Platform Config 4 data with size :- 348
[ 0.9935 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 0.9936 ] Added Platform Config 3 data with size :- 92
[ 0.9937 ]
[ 0.9937 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 0.9937 ] Added Platform Config 5 data with size :- 68
[ 0.9937 ]
[ 0.9937 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 0.9937 ] Added Platform Config 7 data with size :- 392
[ 0.9937 ]
[ 0.9937 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 0.9937 ] Added Platform Config 8 data with size :- 12
[ 0.9937 ]
[ 0.9937 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 0.9937 ] Added Platform Config 9 data with size :- 32
[ 0.9937 ]
[ 0.9937 ] Updating mb1-bct with firmware information
[ 0.9957 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 0.9967 ] Updating mb1-bct with storage information
[ 0.9984 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.9994 ] Updating mb1-bct with ratchet information
[ 1.0012 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 1.0019 ] FwIndex: 1, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 2, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 3, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 4, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 5, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 6, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 7, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 11, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 12, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 13, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 14, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 15, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 16, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 17, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 18, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 19, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 30, MinRatchetLevel: 0
[ 1.0021 ] FwIndex: 31, MinRatchetLevel: 0
[ 1.0021 ]
[ 1.0028 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[ 1.0053 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 1.0061 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 1.0263 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.0264 ] Assuming zero filled SBK key
[ 1.0277 ] Warning: pub_key.key is not found
[ 1.0107 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 1.0118 ] Generating coldboot mem-bct
[ 1.0136 ] tegrabct_v2 --chip 0x19 0 --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --membct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_1.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_2.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_3.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_4.bct
[ 1.0142 ] Packing sdram param for instance[0]
[ 1.0509 ] Packing sdram param for instance[1]
[ 1.0510 ] Packing sdram param for instance[2]
[ 1.0510 ] Packing sdram param for instance[3]
[ 1.0511 ] Packing sdram param for instance[4]
[ 1.0511 ] Packing sdram param for instance[5]
[ 1.0512 ] Packing sdram param for instance[6]
[ 1.0513 ] Packing sdram param for instance[7]
[ 1.0513 ] Packing sdram param for instance[8]
[ 1.0513 ] Packing sdram param for instance[9]
[ 1.0513 ] Packing sdram param for instance[10]
[ 1.0513 ] Packing sdram param for instance[11]
[ 1.0513 ] Packing sdram param for instance[12]
[ 1.0513 ] Packing sdram param for instance[13]
[ 1.0513 ] Packing sdram param for instance[14]
[ 1.0513 ] Packing sdram param for instance[15]
[ 1.0513 ]
[ 1.0514 ] Getting sector size from pt
[ 1.0524 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 1.0531 ] BlockSize read from layout is 200
[ 1.0550 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_1.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_2.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_3.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_4.bct
[ 1.0557 ] adding BCH for /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_1.bct
[ 1.0578 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 1.0592 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 1.0598 ] Header already present for mem_coldboot_aligned.bct
[ 1.0796 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.0798 ] Assuming zero filled SBK key
[ 1.0811 ] Warning: pub_key.key is not found
[ 1.0640 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 1.0650 ] Generating recovery mem-bct
[ 1.0669 ] tegrabct_v2 --chip 0x19 0 --sdram /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31.cfg --membct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_1.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_2.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_3.bct /home/erian/Documents/nvidia/JetPack_5.0.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/206824/tmpr83okmt31_4.bct
[ 1.0676 ] Packing sdram param for instance[0]
[ 1.1043 ] Packing sdram param for instance[1]
[ 1.1044 ] Packing sdram param for instance[2]
[ 1.1044 ] Packing sdram param for instance[3]
[ 1.1045 ] Packing sdram param for instance[4]
[ 1.1045 ] Packing sdram param for instance[5]
[ 1.1045 ] Packing sdram param for instance[6]
[ 1.1045 ] Packing sdram param for instance[7]
[ 1.1045 ] Packing sdram param for instance[8]
[ 1.1045 ] Packing sdram param for instance[9]
[ 1.1045 ] Packing sdram param for instance[10]
[ 1.1045 ] Packing sdram param for instance[11]
[ 1.1045 ] Packing sdram param for instance[12]
[ 1.1045 ] Packing sdram param for instance[13]
[ 1.1045 ] Packing sdram param for instance[14]
[ 1.1045 ] Packing sdram param for instance[15]
[ 1.1045 ]
[ 1.1057 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[ 1.1073 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 1.1079 ] adding BCH for mem_rcm_aligned.bct
[ 1.1285 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.1286 ] Assuming zero filled SBK key
[ 1.1298 ] Warning: pub_key.key is not found
[ 1.1128 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 1.1141 ] Copying signatures
[ 1.1148 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.2531 ] Boot Rom communication
[ 1.2543 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 1.2550 ] BR_CID: 0x880219116459e587100000000c0100c0
[ 1.2553 ] RCM version 0X190001
[ 1.2558 ] Boot Rom communication completed
[ 3.2759 ] tegrarcm_v2 --isapplet
[ 3.2766 ] Applet version 01.00.0000
[ 3.2785 ] Sending BCTs
[ 3.2804 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 3.2811 ] Applet version 01.00.0000
[ 3.2828 ] Sending bct_bootrom
[ 3.2828 ] [................................................] 100%
[ 3.2840 ] Sending bct_mb1
[ 3.2891 ] [................................................] 100%
[ 3.2928 ] Sending bct_mem
[ 3.3373 ] [................................................] 100%
[ 3.3805 ] Generating blob
[ 3.3818 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 3.3833 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194_aligned.bin zerosbk
[ 3.3840 ] adding BCH for blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 3.4069 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.4070 ] Assuming zero filled SBK key
[ 3.4083 ] Warning: pub_key.key is not found
[ 3.3924 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.hash zerosbk
[ 3.3960 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194_aligned.bin
[ 3.3977 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194_aligned.bin zerosbk
[ 3.3984 ] adding BCH for blob_nvtboot_recovery_t194_aligned.bin
[ 3.4208 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.4209 ] Assuming zero filled SBK key
[ 3.4223 ] Warning: pub_key.key is not found
[ 3.4064 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_t194_aligned_sigheader.bin.hash zerosbk
[ 3.4106 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr_aligned.bin
[ 3.4119 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
[ 3.4125 ] Header already present for blob_preboot_c10_prod_cr_aligned.bin
[ 3.4325 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.4326 ] Assuming zero filled SBK key
[ 3.4338 ] Warning: pub_key.key is not found
[ 3.4178 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_aligned_sigheader.bin.encrypt blob_preboot_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 3.4195 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr_aligned.bin
[ 3.4209 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr_aligned.bin zerosbk
[ 3.4215 ] Header already present for blob_mce_c10_prod_cr_aligned.bin
[ 3.4423 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.4424 ] Assuming zero filled SBK key
[ 3.4436 ] Warning: pub_key.key is not found
[ 3.4266 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mce_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 3.4306 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr_aligned.bin
[ 3.4331 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
[ 3.4337 ] adding BCH for blob_mts_c10_prod_cr_aligned.bin
[ 3.4944 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.4945 ] Assuming zero filled SBK key
[ 3.5003 ] Warning: pub_key.key is not found
[ 3.4833 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mts_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 3.5082 ] tegrahost_v2 --chip 0x19 --align blob_bpmp-2_t194_aligned.bin
[ 3.5098 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
[ 3.5104 ] adding BCH for blob_bpmp-2_t194_aligned.bin
[ 3.5426 ] tegrasign_v3.py --key None --list blob_bpmp-2_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.5427 ] Assuming zero filled SBK key
[ 3.5451 ] Warning: pub_key.key is not found
[ 3.5282 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp-2_t194_aligned_sigheader.bin.encrypt blob_bpmp-2_t194_aligned_sigheader.bin.hash zerosbk
[ 3.5371 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 3.5385 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb zerosbk
[ 3.5391 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 3.5600 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 3.5601 ] Assuming zero filled SBK key
[ 3.5613 ] Warning: pub_key.key is not found
[ 3.5454 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned_sigheader.dtb.hash zerosbk
[ 3.5476 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194_aligned.bin
[ 3.5488 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194_aligned.bin zerosbk
[ 3.5494 ] adding BCH for blob_spe_t194_aligned.bin
[ 3.5705 ] tegrasign_v3.py --key None --list blob_spe_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.5706 ] Assuming zero filled SBK key
[ 3.5718 ] Warning: pub_key.key is not found
[ 3.5548 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_aligned_sigheader.bin.encrypt blob_spe_t194_aligned_sigheader.bin.hash zerosbk
[ 3.5586 ] tegrahost_v2 --chip 0x19 --align blob_tos-optee_t194_aligned.img
[ 3.5612 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t194_aligned.img zerosbk
[ 3.5619 ] adding BCH for blob_tos-optee_t194_aligned.img
[ 3.5926 ] tegrasign_v3.py --key None --list blob_tos-optee_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 3.5927 ] Assuming zero filled SBK key
[ 3.5948 ] Warning: pub_key.key is not found
[ 3.5779 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-optee_t194_aligned_sigheader.img.encrypt blob_tos-optee_t194_aligned_sigheader.img.hash zerosbk
[ 3.5866 ] tegrahost_v2 --chip 0x19 --align blob_eks_aligned.img
[ 3.5881 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_aligned.img zerosbk
[ 3.5888 ] adding BCH for blob_eks_aligned.img
[ 3.6087 ] tegrasign_v3.py --key None --list blob_eks_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 3.6088 ] Assuming zero filled SBK key
[ 3.6100 ] Warning: pub_key.key is not found
[ 3.5930 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_aligned_sigheader.img.encrypt blob_eks_aligned_sigheader.img.hash zerosbk
[ 3.5947 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 3.5962 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[ 3.5970 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 3.6223 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 3.6224 ] Assuming zero filled SBK key
[ 3.6241 ] Warning: pub_key.key is not found
[ 3.6070 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[ 3.6129 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 3.6136 ] number of images in blob are 11
[ 3.6137 ] blobsize is 6582920
[ 3.6137 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232736
[ 3.6155 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[ 3.6157 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 3.6158 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[ 3.6159 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 3.6172 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[ 3.6178 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt of size 90608
[ 3.6179 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[ 3.6180 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 882112
[ 3.6181 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 3.6182 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 463888
[ 3.6208 ] Sending bootloader and pre-requisite binaries
[ 3.6219 ] tegrarcm_v2 --download blob blob.bin
[ 3.6226 ] Applet version 01.00.0000
[ 3.6250 ] Sending blob
[ 3.6251 ] [................................................] 100%
[ 4.6223 ] tegrarcm_v2 --boot recovery
[ 4.6229 ] Applet version 01.00.0000
[ 5.6317 ] tegrarcm_v2 --isapplet
[ 6.7509 ] tegrarcm_v2 --ismb2
[ 6.7559 ] tegradevflash_v2 --iscpubl
[ 6.7566 ] Bootloader version 01.00.0000
[ 6.7586 ] Bootloader version 01.00.0000
[ 6.7601 ] Retrieving storage infomation
[ 6.7619 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 6.7626 ] Applet is not running on device. Continue with Bootloader
[ 6.7673 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 6.7680 ] Bootloader version 01.00.0000
[ 6.7696 ] Saved platform info in storage_info.bin
[ 6.7713 ] Flashing the device
[ 6.7732 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 6.7738 ] gpt_secondary_0_3.bin:
[ 6.7740 ] partition_id partition_name StartingLba EndingLba
[ 6.7741 ] 1 BCT 0 63
[ 6.7742 ] 2 mb1 64 575
[ 6.7743 ] 3 mb1_b 576 1087
[ 6.7744 ] 4 MB1_BCT 1088 1215
[ 6.7745 ] 5 MEM_BCT 1216 1663
[ 6.7746 ] 6 spe-fw 1664 2175
[ 6.7747 ] 7 mb2 2176 2623
[ 6.7748 ] 8 mts-preboot 2624 2687
[ 6.7750 ] 9 reserved_for_chain_A_boot 2688 6783
[ 6.7751 ] 10 MB1_BCT_b 6784 6911
[ 6.7752 ] 11 MEM_BCT_b 6912 7359
[ 6.7753 ] 12 spe-fw_b 7360 7871
[ 6.7754 ] 13 mb2_b 7872 8319
[ 6.7754 ] 14 mts-preboot_b 8320 8383
[ 6.7754 ] 15 reserved_for_chain_B_boot 8384 12479
[ 6.7754 ] 16 BCT-boot-chain_backup 15616 15743
[ 6.7755 ] 17 reserved_partition 15744 15871
[ 6.7755 ] 18 secondary_gpt_backup 15872 15999
[ 6.7755 ] 19 VER_b 16000 16127
[ 6.7755 ] 20 VER 16128 16255
[ 6.7755 ] gpt_primary_1_3.bin:
[ 6.7755 ] partition_id partition_name StartingLba EndingLba
[ 6.7755 ] 1 APP 40 58720295
[ 6.7755 ] 2 mts-mce 58720296 58720615
[ 6.7755 ] 3 mts-proper 58720616 58728807
[ 6.7755 ] 4 cpu-bootloader 58728808 58736999
[ 6.7755 ] 5 bootloader-dtb 58737000 58738023
[ 6.7755 ] 6 secure-os 58738024 58743143
[ 6.7755 ] 7 eks 58743144 58743271
[ 6.7755 ] 8 bpmp-fw 58743272 58746343
[ 6.7755 ] 9 bpmp-fw-dtb 58746344 58748391
[ 6.7755 ] 10 xusb-fw 58748392 58748711
[ 6.7755 ] 11 rce-fw 58748712 58752807
[ 6.7755 ] 12 adsp-fw 58752808 58756903
[ 6.7755 ] 13 sce-fw 58756904 58758951
[ 6.7755 ] 14 sc7 58758952 58759207
[ 6.7755 ] 15 kernel 58759208 58923047
[ 6.7755 ] 16 kernel-dtb 58923048 58924071
[ 6.7755 ] 17 reserved_for_chain_A_user 58924072 58989607
[ 6.7755 ] 18 mts-mce_b 58990592 58990911
[ 6.7755 ] 19 mts-proper_b 58990912 58999103
[ 6.7755 ] 20 cpu-bootloader_b 58999104 59007295
[ 6.7755 ] 21 bootloader-dtb_b 59007296 59008319
[ 6.7755 ] 22 secure-os_b 59008320 59013439
[ 6.7755 ] 23 eks_b 59013440 59013567
[ 6.7755 ] 24 bpmp-fw_b 59013568 59016639
[ 6.7755 ] 25 bpmp-fw-dtb_b 59016640 59018687
[ 6.7755 ] 26 xusb-fw_b 59018688 59019007
[ 6.7755 ] 27 rce-fw_b 59019008 59023103
[ 6.7755 ] 28 adsp-fw_b 59023104 59027199
[ 6.7755 ] 29 sce-fw_b 59027200 59029247
[ 6.7755 ] 30 sc7_b 59029248 59029503
[ 6.7755 ] 31 kernel_b 59029504 59193343
[ 6.7755 ] 32 kernel-dtb_b 59193344 59194367
[ 6.7755 ] 33 reserved_for_chain_B_user 59194368 59260927
[ 6.7755 ] 34 recovery 59260928 59424767
[ 6.7755 ] 35 recovery-dtb 59424768 59425791
[ 6.7755 ] 36 RP1 59425792 59442175
[ 6.7755 ] 37 RP2 59442176 59458559
[ 6.7755 ] 38 RECROOTFS 59458560 60072959
[ 6.7755 ] 39 uefi_variables 60072960 60073215
[ 6.7755 ] 40 esp 60073216 60204287
[ 6.7755 ] 41 UDA 60204288 61079518
[ 6.7755 ] gpt_secondary_1_3.bin:
[ 6.7756 ] 1 APP 40 58720295
[ 6.7756 ] 2 mts-mce 58720296 58720615
[ 6.7756 ] 3 mts-proper 58720616 58728807
[ 6.7756 ] 4 cpu-bootloader 58728808 58736999
[ 6.7756 ] 5 bootloader-dtb 58737000 58738023
[ 6.7756 ] 6 secure-os 58738024 58743143
[ 6.7756 ] 7 eks 58743144 58743271
[ 6.7756 ] 8 bpmp-fw 58743272 58746343
[ 6.7756 ] 9 bpmp-fw-dtb 58746344 58748391
[ 6.7756 ] 10 xusb-fw 58748392 58748711
[ 6.7756 ] 11 rce-fw 58748712 58752807
[ 6.7756 ] 12 adsp-fw 58752808 58756903
[ 6.7756 ] 13 sce-fw 58756904 58758951
[ 6.7756 ] 14 sc7 58758952 58759207
[ 6.7756 ] 15 kernel 58759208 58923047
[ 6.7756 ] 16 kernel-dtb 58923048 58924071
[ 6.7756 ] 17 reserved_for_chain_A_user 58924072 58989607
[ 6.7756 ] 18 mts-mce_b 58990592 58990911
[ 6.7756 ] 19 mts-proper_b 58990912 58999103
[ 6.7756 ] 20 cpu-bootloader_b 58999104 59007295
[ 6.7756 ] 21 bootloader-dtb_b 59007296 59008319
[ 6.7756 ] 22 secure-os_b 59008320 59013439
[ 6.7756 ] 23 eks_b 59013440 59013567
[ 6.7756 ] 24 bpmp-fw_b 59013568 59016639
[ 6.7756 ] 25 bpmp-fw-dtb_b 59016640 59018687
[ 6.7756 ] 26 xusb-fw_b 59018688 59019007
[ 6.7756 ] 27 rce-fw_b 59019008 59023103
[ 6.7756 ] 28 adsp-fw_b 59023104 59027199
[ 6.7756 ] 29 sce-fw_b 59027200 59029247
[ 6.7756 ] 30 sc7_b 59029248 59029503
[ 6.7756 ] 31 kernel_b 59029504 59193343
[ 6.7756 ] 32 kernel-dtb_b 59193344 59194367
[ 6.7756 ] 33 reserved_for_chain_B_user 59194368 59260927
[ 6.7756 ] 34 recovery 59260928 59424767
[ 6.7756 ] 35 recovery-dtb 59424768 59425791
[ 6.7756 ] 36 RP1 59425792 59442175
[ 6.7756 ] 37 RP2 59442176 59458559
[ 6.7756 ] 38 RECROOTFS 59458560 60072959
[ 6.7756 ] 39 uefi_variables 60072960 60073215
[ 6.7756 ] 40 esp 60073216 60204287
[ 6.7756 ] 41 UDA 60204288 61079518
[ 6.7756 ]
[ 6.7756 ] Start flashing
[ 6.7763 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 6.7769 ] Bootloader version 01.00.0000
[ 6.7785 ] Erasing sdmmc_boot: 3 ......... [Done]
[ 7.9038 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin [ 16896 bytes ]
[ 7.9040 ] [................................................] 100%
[ 7.9375 ] Erasing sdmmc_user: 3 ......... [Done]
[ 8.7087 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 8.7089 ] [................................................] 100%
[ 8.7099 ] Writing partition primary_gpt with gpt_primary_1_3.bin [ 16896 bytes ]
[ 8.7168 ] [................................................] 100%
[ 8.7193 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin [ 16896 bytes ]
[ 8.7396 ] [................................................] 100%
[ 8.7608 ] Writing partition mb1 with mb1_t194_prod_aligned_sigheader.bin.encrypt [ 248944 bytes ]
[ 8.7610 ] [................................................] 100%
[ 8.7713 ] Writing partition mb1_b with mb1_b_t194_prod_aligned_sigheader.bin.encrypt [ 248944 bytes ]
[ 8.7991 ] [................................................] 100%
[ 8.8096 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt [ 95232 bytes ]
[ 8.8353 ] [................................................] 100%
[ 8.8400 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt [ 207584 bytes ]
[ 8.8480 ] [................................................] 100%
[ 8.8570 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt [ 24016 bytes ]
[ 8.8808 ] [................................................] 100%
[ 8.8828 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt [ 95232 bytes ]
[ 8.9015 ] [................................................] 100%
[ 8.9068 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt [ 207584 bytes ]
[ 8.9961 ] [................................................] 100%
[ 9.0046 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt [ 24016 bytes ]
[ 9.1088 ] [................................................] 100%
[ 9.1107 ] Writing partition VER_b with emmc_bootblob_ver.txt [ 109 bytes ]
[ 9.1305 ] [................................................] 100%
[ 9.1326 ] Writing partition VER with emmc_bootblob_ver.txt [ 109 bytes ]
[ 9.2247 ] [................................................] 100%
[ 9.2259 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 9.2396 ] [................................................] 100%
[ 9.2407 ] Writing partition APP with system.img [ 5690367208 bytes ]
[ 9.2481 ] [................................................] 100%
[ 312.6130 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt [ 145184 bytes ]
[ 312.6593 ] [................................................] 100%
[ 312.6653 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt [ 3430416 bytes ]
[ 312.6911 ] [................................................] 100%
[ 312.8873 ] Writing partition cpu-bootloader with nvdisp-init_sigheader.bin.encrypt [ 3149824 bytes ]
[ 312.9116 ] [................................................] 100%
[ 313.0837 ] Writing partition bootloader-dtb with tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt [ 463888 bytes ]
[ 313.0926 ] [................................................] 100%
[ 313.1086 ] Writing partition secure-os with tos-optee_t194_sigheader.img.encrypt [ 882112 bytes ]
[ 313.1306 ] [................................................] 100%
[ 313.1636 ] Writing partition eks with eks_sigheader.img.encrypt [ 5136 bytes ]
[ 313.1882 ] [................................................] 100%
[ 313.1905 ] Writing partition bpmp-fw with bpmp-2_t194_sigheader.bin.encrypt [ 1007392 bytes ]
[ 313.2110 ] [................................................] 100%
[ 313.2464 ] Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt [ 90608 bytes ]
[ 313.2743 ] [................................................] 100%
[ 313.2768 ] Writing partition xusb-fw with xusb_sil_rel_fw_sigheader.encrypt [ 133120 bytes ]
[ 313.2963 ] [................................................] 100%
[ 313.3024 ] Writing partition rce-fw with camera-rtcpu-t194-rce_sigheader.img.encrypt [ 529776 bytes ]
[ 313.3095 ] [................................................] 100%
[ 313.3273 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt [ 396880 bytes ]
[ 313.3520 ] [................................................] 100%
[ 313.3672 ] Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt [ 55264 bytes ]
[ 313.3891 ] [................................................] 100%
[ 313.3922 ] Writing partition kernel with boot.img [ 42057728 bytes ]
[ 313.4083 ] [................................................] 100%
[ 315.8269 ] Writing partition kernel-dtb with kernel_tegra194-p2888-0001-p2822-0000.dtb [ 376766 bytes ]
[ 315.8354 ] [................................................] 100%
[ 315.8490 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt [ 145184 bytes ]
[ 315.8715 ] [................................................] 100%
[ 315.8768 ] Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt [ 3430416 bytes ]
[ 315.9001 ] [................................................] 100%
[ 316.0872 ] Writing partition cpu-bootloader_b with nvdisp-init_sigheader.bin.encrypt [ 3149824 bytes ]
[ 316.1096 ] [................................................] 100%
[ 316.2931 ] Writing partition bootloader-dtb_b with tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt [ 463888 bytes ]
[ 316.3023 ] [................................................] 100%
[ 316.3177 ] Writing partition secure-os_b with tos-optee_t194_sigheader.img.encrypt [ 882112 bytes ]
[ 316.3418 ] [................................................] 100%
[ 316.3745 ] Writing partition eks_b with eks_sigheader.img.encrypt [ 5136 bytes ]
[ 316.4008 ] [................................................] 100%
[ 316.4039 ] Writing partition bpmp-fw_b with bpmp-2_t194_sigheader.bin.encrypt [ 1007392 bytes ]
[ 316.4255 ] [................................................] 100%
[ 316.4622 ] Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt [ 90608 bytes ]
[ 316.4911 ] [................................................] 100%
[ 316.4942 ] Writing partition xusb-fw_b with xusb_sil_rel_fw_sigheader.encrypt [ 133120 bytes ]
[ 316.5148 ] [................................................] 100%
[ 316.5173 ] Writing partition rce-fw_b with camera-rtcpu-t194-rce_sigheader.img.encrypt [ 529776 bytes ]
[ 316.5263 ] [................................................] 100%
[ 316.5461 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt [ 396880 bytes ]
[ 316.5697 ] [................................................] 100%
[ 316.5856 ] Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt [ 55264 bytes ]
[ 316.6082 ] [................................................] 100%
[ 316.6105 ] Writing partition kernel_b with boot.img [ 42057728 bytes ]
[ 316.6300 ] [................................................] 100%
[ 319.1260 ] Writing partition kernel-dtb_b with kernel_tegra194-p2888-0001-p2822-0000.dtb [ 376766 bytes ]
[ 319.1358 ] [................................................] 100%
[ 319.1482 ] Writing partition recovery with recovery.img [ 45832192 bytes ]
[ 319.1698 ] [................................................] 100%
[ 321.8358 ] Writing partition recovery-dtb with tegra194-p2888-0001-p2822-0000.dtb.rec [ 376766 bytes ]
[ 321.8493 ] [................................................] 100%
[ 321.8620 ] Writing partition esp with esp.img [ 67108864 bytes ]
[ 321.8832 ] [................................................] 100%
[ 325.8243 ] tegradevflash_v2 --write secondary_gpt_backup gpt_secondary_0_3.bin
[ 325.8259 ] Bootloader version 01.00.0000
[ 325.8280 ] Writing partition secondary_gpt_backup with gpt_secondary_0_3.bin [ 16896 bytes ]
[ 325.8281 ] [................................................] 100%
[ 325.8423 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 325.8442 ] Bootloader version 01.00.0000
[ 325.8460 ] Writing partition BCT with br_bct_BR.bct [ 2888 bytes ]
[ 325.8463 ] [................................................] 100%
[ 325.9913 ] tegradevflash_v2 --write BCT-boot-chain_backup bct_backup.img
[ 325.9933 ] Bootloader version 01.00.0000
[ 325.9965 ] Writing partition BCT-boot-chain_backup with bct_backup.img [ 32768 bytes ]
[ 325.9970 ] [................................................] 100%
[ 326.0105 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 326.0122 ] Bootloader version 01.00.0000
[ 326.0141 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 31024 bytes ]
[ 326.0147 ] [................................................] 100%
[ 326.0406 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 326.0428 ] Bootloader version 01.00.0000
[ 326.0457 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 31024 bytes ]
[ 326.0462 ] [................................................] 100%
[ 326.1535 ] tegradevflash_v2 --write MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 326.1554 ] Bootloader version 01.00.0000
[ 326.1584 ] Writing partition MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 198656 bytes ]
[ 326.1589 ] [................................................] 100%
[ 326.2650 ] tegradevflash_v2 --write MEM_BCT_b mem_coldboot_sigheader.bct.encrypt
[ 326.2669 ] Bootloader version 01.00.0000
[ 326.2696 ] Writing partition MEM_BCT_b with mem_coldboot_sigheader.bct.encrypt [ 198656 bytes ]
[ 326.2700 ] [................................................] 100%
[ 326.2925 ] Flashing completed
[ 326.2927 ] Coldbooting the device
[ 326.2967 ] tegrarcm_v2 --ismb2
[ 326.3039 ] tegradevflash_v2 --reboot coldboot
[ 326.3064 ] Bootloader version 01.00.0000
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
Do you use the following command to flash your Xavier devkit?
$ sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1
From your flash log, it looks fine and flash successfully.
Do you have other Xavier devkit with the same problem?
Are you using standalone Ubuntu 20.04 as your host PC?
What’s the message from serial console? (it stops at UEFI or hit kernel panic?)
Yes, I use that command to flash. I am using 20.04 Ubuntu LTS. I do not have any Xavier devkit. Based on the serial console log, it stops here:
Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
After the next boot, it shows this:
** WARNING: Test Key is used. **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-5273-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 10 2
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x859b67318 SMBIOS=0xc7db0000 SMBIOS 3.0=0x87c210000 MEMATTR=0x858842018 ESRT=0x858878718 RNG=0x87c255a98 MEMRESERVE=0x858843f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000858878718 to 0x0000000858878750.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a096afff]
[ 0.000000] node 0: [mem 0x00000000a096b000-0x00000000a096cfff]
[ 0.000000] node 0: [mem 0x00000000a096e000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c7bfffff]
[ 0.000000] node 0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[ 0.000000] node 0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000008572cafff]
[ 0.000000] node 0: [mem 0x00000008572cb000-0x0000000857d6ffff]
[ 0.000000] node 0: [mem 0x0000000857d70000-0x000000085812ffff]
[ 0.000000] node 0: [mem 0x0000000858130000-0x000000085813ffff]
[ 0.000000] node 0: [mem 0x0000000858140000-0x00000008587fffff]
[ 0.000000] node 0: [mem 0x0000000858800000-0x000000085882ffff]
[ 0.000000] node 0: [mem 0x0000000858830000-0x000000085884ffff]
[ 0.000000] node 0: [mem 0x0000000858850000-0x000000085886ffff]
[ 0.000000] node 0: [mem 0x0000000858870000-0x00000008589cffff]
[ 0.000000] node 0: [mem 0x00000008589d0000-0x0000000858baffff]
[ 0.000000] node 0: [mem 0x0000000858bb0000-0x0000000858c1ffff]
[ 0.000000] node 0: [mem 0x0000000858c20000-0x0000000858d4ffff]
[ 0.000000] node 0: [mem 0x0000000858d50000-0x0000000858d5ffff]
[ 0.000000] node 0: [mem 0x0000000858d60000-0x0000000858dfffff]
[ 0.000000] node 0: [mem 0x0000000858e00000-0x0000000858ebffff]
[ 0.000000] node 0: [mem 0x0000000858ec0000-0x0000000858eeffff]
[ 0.000000] node 0: [mem 0x0000000858ef0000-0x0000000858f2ffff]
[ 0.000000] node 0: [mem 0x0000000858f30000-0x00000008590bffff]
[ 0.000000] node 0: [mem 0x00000008590c0000-0x000000085954ffff]
[ 0.000000] node 0: [mem 0x0000000859550000-0x000000085968ffff]
[ 0.000000] node 0: [mem 0x0000000859690000-0x000000085969ffff]
[ 0.000000] node 0: [mem 0x00000008596a0000-0x00000008596cffff]
[ 0.000000] node 0: [mem 0x00000008596d0000-0x0000000859e8ffff]
[ 0.000000] node 0: [mem 0x0000000859e90000-0x0000000859f2ffff]
[ 0.000000] node 0: [mem 0x0000000859f30000-0x0000000859fdffff]
[ 0.000000] node 0: [mem 0x0000000859fe0000-0x000000085a07ffff]
[ 0.000000] node 0: [mem 0x000000085a080000-0x000000085a10ffff]
[ 0.000000] node 0: [mem 0x000000085a110000-0x000000085a1affff]
[ 0.000000] node 0: [mem 0x000000085a1b0000-0x000000085aa7ffff]
[ 0.000000] node 0: [mem 0x000000085aa80000-0x000000085ac5ffff]
[ 0.000000] node 0: [mem 0x000000085ac60000-0x000000087c20ffff]
[ 0.000000] node 0: [mem 0x000000087c210000-0x000000087c25ffff]
[ 0.000000] node 0: [mem 0x000000087c260000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8032420
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[ 0.000000] Memory: 31669184K/32639676K available (18432K kernel code, 3172K rwdata, 7156K rodata, 3968K init, 1095K bss, 904956K reserved, 65536K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000624] Console: colour dummy device 80x25
[ 0.001864] printk: console [tty0] enabled
[ 0.001920] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001949] pid_max: default: 32768 minimum: 301
[ 0.002097] LSM: Security Framework initializing
[ 0.002151] Yama: becoming mindful.
[ 0.002189] SELinux: Initializing.
[ 0.002337] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002399] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.005491] rcu: Hierarchical SRCU implementation.
[ 0.005731] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.006305] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0000-p3509-0000.dts
[ 0.006344] DTB Build time: Aug 10 2022 20:31:49
[ 0.008639] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.008862] Remapping and enabling EFI services.
[ 0.010756] smp: Bringing up secondary CPUs ...
[ 0.040337] Detected PIPT I-cache on CPU1
[ 0.040431] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.069885] Detected PIPT I-cache on CPU2
[ 0.070034] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.099508] Detected PIPT I-cache on CPU3
[ 0.099647] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.129246] Detected PIPT I-cache on CPU4
[ 0.129403] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.159130] Detected PIPT I-cache on CPU5
[ 0.159223] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.189022] Detected PIPT I-cache on CPU6
[ 0.189101] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[ 0.218740] Detected PIPT I-cache on CPU7
[ 0.218831] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[ 0.219290] smp: Brought up 1 node, 8 CPUs
[ 0.219458] SMP: Total of 8 processors activated.
[ 0.219515] CPU features: detected: Privileged Access Never
[ 0.219535] CPU features: detected: LSE atomic instructions
[ 0.219546] CPU features: detected: User Access Override
[ 0.219557] CPU features: detected: 32-bit EL0 Support
[ 0.219567] CPU features: detected: RAS Extension Support
[ 0.219577] CPU features: detected: CRC32 instructions
[ 0.219588] CPU features: detected: 32-bit EL1 Support
[ 0.280153] CPU: All CPU(s) started at EL2
[ 0.289718] devtmpfs: initialized
[ 0.330882] Registered cp15_barrier emulation handler
[ 0.330994] Registered setend emulation handler
[ 0.331015] KASLR enabled
[ 0.331214] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.331237] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.332493] pinctrl core: initialized pinctrl subsystem
[ 0.333344] SMBIOS 3.0.0 present.
[ 0.333370] DMI: Unknown Jetson-AGX/Jetson-AGX, BIOS 1.0-d7fb19b 08/10/2022
[ 0.333934] NET: Registered protocol family 16
[ 0.336331] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.337912] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.339483] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.339548] audit: initializing netlink subsys (disabled)
[ 0.339885] audit: type=2000 audit(0.336:1): state=initialized audit_enabled=0 res=1
[ 0.340213] thermal_sys: Registered thermal governor 'step_wise'
[ 0.340219] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.340232] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.342347] cpuidle: using governor menu
[ 0.342682] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.343276] ASID allocator initialised with 32768 entries
[ 0.343480] Serial: AMBA PL011 UART driver
[ 0.346220] Tegra reboot handler registered.
[ 0.401497] tegra19x-cbb 2300000.cbb-noc: axi2apb bridge info present
[ 0.401700] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[ 0.401877] tegra19x-cbb c600000.aon-noc: axi2apb bridge info present
[ 0.401917] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[ 0.402026] tegra19x-cbb d600000.bpmp-noc: axi2apb bridge info present
[ 0.402064] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[ 0.402175] tegra19x-cbb be00000.rce-noc: axi2apb bridge info present
[ 0.402235] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[ 0.402363] tegra19x-cbb b600000.sce-noc: axi2apb bridge info present
[ 0.402416] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[ 0.404534] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[ 0.404566] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[ 0.404589] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[ 0.404611] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[ 0.404634] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[ 0.404655] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[ 0.404679] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[ 0.404704] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[ 0.404731] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[ 0.404755] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[ 0.404777] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[ 0.404799] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[ 0.404829] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[ 0.404850] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[ 0.404872] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[ 0.404893] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[ 0.404915] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[ 0.405016] mc-err: mcerr ops are set to t19x
[ 0.414483] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.414501] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.414512] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.414522] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.420718] ACPI: Interpreter disabled.
[ 0.421658] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.422691] iommu: Default domain type: Translated
[ 0.422756] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.423115] SCSI subsystem initialized
[ 0.423239] usbcore: registered new interface driver usbfs
[ 0.423269] usbcore: registered new interface driver hub
[ 0.423297] usbcore: registered new device driver usb
[ 0.423641] mc: Linux media interface: v0.10
[ 0.423663] videodev: Linux video capture interface: v2.00
[ 0.423906] pps_core: LinuxPPS API ver. 1 registered
[ 0.423916] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.423936] PTP clock support registered
[ 0.424104] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.424357] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.424440] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.424917] Registered efivars operations
[ 0.429592] FPGA manager framework
[ 0.429677] Advanced Linux Sound Architecture Driver Initialized.
[ 0.430183] Bluetooth: Core ver 2.22
[ 0.430232] NET: Registered protocol family 31
[ 0.430243] Bluetooth: HCI device and connection manager initialized
[ 0.430256] Bluetooth: HCI socket layer initialized
[ 0.430269] Bluetooth: L2CAP socket layer initialized
[ 0.430309] Bluetooth: SCO socket layer initialized
[ 0.431751] camchar: rtcpu character device driver loaded
[ 0.432315] clocksource: Switched to clocksource arch_sys_counter
[ 0.684430] VFS: Disk quotas dquot_6.6.0
[ 0.684496] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.684785] pnp: PnP ACPI: disabled
[ 0.695157] la/ptsa driver initialized.
[ 0.695268] NET: Registered protocol family 2
[ 0.695493] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.703946] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.704229] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.705024] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.705399] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.705560] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.705825] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.706200] NET: Registered protocol family 1
[ 0.706854] RPC: Registered named UNIX socket transport module.
[ 0.706867] RPC: Registered udp transport module.
[ 0.706875] RPC: Registered tcp transport module.
[ 0.706883] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.706896] PCI: CLS 0 bytes, default 64
[ 0.707091] Trying to unpack rootfs image as initramfs...
[ 0.865997] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 0.867702] Freeing initrd memory: 8196K
[ 0.871704] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.872071] kvm [1]: IPA Size Limit: 40 bits
[ 0.872609] kvm [1]: vgic interrupt IRQ9
[ 0.873138] kvm [1]: VHE mode initialized successfully
[ 0.874225] Initialise system trusted keyrings
[ 0.874471] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.877653] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.878177] NFS: Registering the id_resolver key type
[ 0.878198] Key type id_resolver registered
[ 0.878207] Key type id_legacy registered
[ 0.878256] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.878271] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.878293] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.884818] NET: Registered protocol family 38
[ 0.884836] Key type asymmetric registered
[ 0.884845] Asymmetric key parser 'x509' registered
[ 0.884884] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.885077] io scheduler mq-deadline registered
[ 0.885089] io scheduler kyber registered
[ 0.888934] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[ 0.890848] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.890905] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.890954] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.890999] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 0.891069] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.894570] scrncapt: init (heads:4 wins:6 planes:4)
[ 0.895006] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 0.895656] EINJ: ACPI disabled.
[ 0.897679] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.897698] tegra-pmc: ### PMC reset source: BCCPLEXWDT
[ 0.897707] tegra-pmc: ### PMC reset level: L1
[ 0.897715] tegra-pmc: ### PMC reset status reg: 0x9
[ 0.897753] tegra-pmc: PMC Prod config success
[ 0.901904] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.382648] random: fast init done
[ 2.483558] printk: console [ttyTCU0] enabled
[ 2.488767] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.494216] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.498668] arm-smmu 10000000.iommu: stage 1 translation
[ 2.504278] arm-smmu 10000000.iommu: stage 2 translation
[ 2.509786] arm-smmu 10000000.iommu: nested translation
[ 2.514856] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.522032] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.531527] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.535709] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.542239] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.549376] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.555297] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.560001] arm-smmu 12000000.iommu: stage 1 translation
[ 2.565511] arm-smmu 12000000.iommu: stage 2 translation
[ 2.570679] arm-smmu 12000000.iommu: nested translation
[ 2.576377] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.583285] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.592587] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.596416] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.603242] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.610468] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.620799] tegra_profiler: version: 1.147, samples/io: 49/28
[ 2.623642] tegra_profiler: auth: init
[ 2.627584] THERMAL EST: found 3 subdevs
[ 2.631329] THERMAL EST num_resources: 0
[ 2.635165] [THERMAL EST subdev 0]
[ 2.638228] [THERMAL EST subdev 1]
[ 2.641641] [THERMAL EST subdev 2]
[ 2.645148] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.651529] THERMAL EST: thz register success.
[ 2.655837] THERMAL EST: end of probe, return err: 0
[ 2.660780] nvsciipc: loaded module
[ 2.666974] tun: Universal TUN/TAP device driver, 1.6
[ 2.670120] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.676675] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.682473] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.687144] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.693480] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.698778] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.704924] PPP generic driver version 2.4.2
[ 2.708948] PPP BSD Compression module registered
[ 2.713516] PPP Deflate Compression module registered
[ 2.718999] PPP MPPE Compression module registered
[ 2.723766] usbcore: registered new interface driver r8152
[ 2.729536] usbcore: registered new interface driver asix
[ 2.734603] usbcore: registered new interface driver ax88179_178a
[ 2.740720] usbcore: registered new interface driver cdc_ether
[ 2.746914] usbcore: registered new interface driver net1080
[ 2.752513] usbcore: registered new interface driver cdc_subset
[ 2.758550] usbcore: registered new interface driver zaurus
[ 2.763991] usbcore: registered new interface driver cdc_ncm
[ 2.769953] usbcore: registered new interface driver aqc111
[ 2.775513] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.781402] ohci-pci: OHCI PCI platform driver
[ 2.786008] ohci-platform: OHCI generic platform driver
[ 2.791470] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.797527] usbcore: registered new interface driver uas
[ 2.802003] usbcore: registered new interface driver usb-storage
[ 2.808331] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.814307] mousedev: PS/2 mouse device common for all mice
[ 2.819155] usbcore: registered new interface driver xpad
[ 2.826994] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.830154] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:30 UTC (30)
[ 2.837677] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.844048] i2c /dev entries driver
[ 2.847505] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.853309] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.858561] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.864288] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.869339] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.874897] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.880325] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.892127] device-mapper: uevent: version 1.0.3
[ 2.892551] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.900364] cpuidle: Initializing cpuidle driver
[ 2.904900] sdhci: Secure Digital Host Controller Interface driver
[ 2.909487] sdhci: Copyright(c) Pierre Ossman
[ 2.913599] Synopsys Designware Multimedia Card Interface Driver
[ 2.919723] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.926296] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 2.926679] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 2.939103] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 2.956278] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 2.964619] vdd-1v0: supplied by regulator-dummy
[ 2.969902] vdd-1v8-hs: supplied by regulator-dummy
[ 2.974443] vdd-1v8-ls: supplied by regulator-dummy
[ 2.979033] vdd-1v8-ao: supplied by regulator-dummy
[ 2.982757] vddio-ddr-1v1: supplied by regulator-dummy
[ 2.986937] vdd-rtc: supplied by regulator-dummy
[ 2.988515] spmic-ldo1: supplied by regulator-dummy
[ 2.989577] vdd-ao-3v3: supplied by regulator-dummy
[ 2.995542] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.001645] spmic-ldo4: supplied by regulator-dummy
[ 3.002844] vdd-usb-3v3: supplied by regulator-dummy
[ 3.010842] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.016802] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.022105] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.023345] gpio-510 (gpio_default): hogged as output/high
[ 3.025722] gpio-511 (gpio_default): hogged as output/high
[ 3.032739] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.170942] max77686-rtc max77620-rtc: registered as rtc0
[ 3.171844] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 3.172092] max77620 4-003c: max77620 probe successful
��debugfs initialized
��[ 3.960711] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.961709] hid: raw HID events driver (C) Jiri Kosina
[ 3.962328] usbcore: registered new interface driver usbhid
[ 3.962470] usbhid: USB HID core driver
[ 3.964419] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[ 3.965475] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[ 31.225762] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 31.300573] Camera-FW on t194-rce-safe ready SHA1=d48f1e27 (crt 0.773 ms, total boot 75.614 ms)
��[ 4.050632] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.051268] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.052254] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.053015] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.054670] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.055380] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.055949] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.057501] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[ 4.057784] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.059729] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=d48f1e279e6679b09020947e8de088eabfeaa475
[ 4.065932] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 4.073167] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.078224] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.085325] denver_knobs_init:MTS_VERSION:55637613
[ 4.100438] t19x_cache tegra-cache: probed
[ 4.102678] optee: probing for conduit method.
[ 4.103502] optee: revision 3.16 (65cc2218)
[ 4.104633] optee: dynamic shared memory is enabled
[ 4.105605] optee: initialized driver
[ 4.111982] nvpmodel: initialized successfully
[ 4.112670] tegra_hv: get_hvd: not initialized yet
[ 4.117349] user_ivc_mempool: hypervisor not present
[ 4.122983] usbcore: registered new interface driver snd-usb-audio
[ 4.129490] u32 classifier
[ 4.130877] input device check on
[ 4.134719] Actions configured
[ 4.138167] Initializing XFRM netlink socket
[ 4.143241] NET: Registered protocol family 10
[ 4.149091] Segment Routing with IPv6
[ 4.150722] NET: Registered protocol family 17
[ 4.154731] NET: Registered protocol family 15
[ 4.159399] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.172891] Bluetooth: RFCOMM socket layer initialized
[ 4.177465] Bluetooth: RFCOMM ver 1.11
[ 4.181571] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.187412] Bluetooth: HIDP socket layer initialized
[ 4.193222] 9pnet: Installing 9P2000 support
[ 4.196884] Key type dns_resolver registered
[ 4.201989] registered taskstats version 1
[ 4.205068] Loading compiled-in X.509 certificates
[ 4.216220] Loaded X.509 cert 'Build time autogenerated kernel key: 90ac610178c49616e6b7af33d5f8183bf0ea1ee9'
[ 4.221094] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 4.312715] CPU:0, Error:cbb-noc@0x2300000,irq=15
[ 4.312855] **************************************
[ 4.313008] CPU:0, Error:cbb-noc
[ 4.313091] Error Logger : 0
[ 4.313173] ErrLog0 : 0x80030000
[ 4.313288] Transaction Type : RD - Read, Incrementing
[ 4.313415] Error Code : SLV
[ 4.313494] Error Source : Target
[ 4.313579] Error Description : Target error detected by CBB slave
[ 4.313764] AXI2APB_2 bridge error: SFIFONE - Status FIFO Not Empty interrupt
[ 4.313981] AXI2APB_2 bridge error: TIM - Timer(Timeout) interrupt
[ 4.314139] Packet header Lock : 0
[ 4.314223] Packet header Len1 : 3
[ 4.314307] NOC protocol version : version >= 2.7
[ 4.314420] ErrLog1 : 0x320026
[ 4.314519] ErrLog2 : 0x0
[ 4.314589] RouteId : 0x320026
[ 4.314670] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 4.314802] Targflow : axis_satellite_grout/T/axis_satellite_grout
[ 4.314949] TargSubRange : 0
[ 4.315058] SeqId : 0
[ 4.317577] ErrLog3 : 0x3f40078
[ 4.320555] ErrLog4 : 0x0
[ 4.323712] Address accessed : 0x3f40078
[ 4.327904] ErrLog5 : 0x989f851
[ 4.330970] Non-Modify : 0x1
[ 4.334380] AXI ID : 0x13
[ 4.337535] Master ID : CCPLEX
[ 4.341026] Security Group(GRPSEC): 0x7e
[ 4.345144] Cache : 0x1 -- Bufferable
[ 4.349117] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 4.355905] FALCONSEC : 0x0
[ 4.359056] Virtual Queuing Channel(VQC): 0x0
[ 4.363696] **************************************
[ 4.369054] ------------[ cut here ]------------
[ 4.373237] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:1896!
[ 4.379807] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 4.384973] Modules linked in:
[ 4.388384] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.104-tegra #1
[ 4.395188] Hardware name: Unknown Jetson-AGX/Jetson-AGX, BIOS 1.0-d7fb19b 08/10/2022
[ 4.402901] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 4.408532] pc : tegra194_cbb_err_isr+0x190/0x1b0
[ 4.413478] lr : tegra194_cbb_err_isr+0x114/0x1b0
[ 4.418202] sp : ffff800010003b30
[ 4.421354] x29: ffff800010003b30 x28: 0000000000000001
[ 4.427130] x27: 0000000000000005 x26: ffffbe82b6493f58
[ 4.432550] x25: ffffbe82b6dece10 x24: 0000000000000001
[ 4.437719] x23: ffffbe82b6787000 x22: ffffbe82b6c0ea00
[ 4.443400] x21: 000000000000000f x20: ffff089dc0fbf880
[ 4.448481] x19: ffffbe82b6c0ea00 x18: 0000000000000010
[ 4.453991] x17: 000000000000020e x16: 000000004e882f71
[ 4.459417] x15: ffff089dc013eaf0 x14: 0720072007200720
[ 4.465044] x13: 0720072007200720 x12: 0720072007200720
[ 4.470266] x11: 0720072007200720 x10: 0720072007200720
[ 4.476043] x9 : 0720072007200720 x8 : 07200720072a072a
[ 4.481582] x7 : 072a072a072a072a x6 : c0000000ffffefff
[ 4.487063] x5 : 0000000000057fa8 x4 : ffffbe82b6a97968
[ 4.492486] x3 : 00000000ffffffff x2 : ffffbe82b4f2e090
[ 4.497825] x1 : ffff089dc013e580 x0 : 0000000100010100
[ 4.502909] Call trace:
[ 4.505370] tegra194_cbb_err_isr+0x190/0x1b0
[ 4.509965] __handle_irq_event_percpu+0x68/0x2a0
[ 4.514373] handle_irq_event_percpu+0x40/0xa0
[ 4.518702] handle_irq_event+0x50/0xf0
[ 4.522687] handle_fasteoi_irq+0xc0/0x170
[ 4.526748] generic_handle_irq+0x40/0x60
[ 4.530727] __handle_domain_irq+0x70/0xd0
[ 4.534677] efi_header_end+0xb0/0xf0
[ 4.538429] el1_irq+0xd0/0x180
[ 4.541401] __do_softirq+0xb4/0x3e8
[ 4.545118] irq_exit+0xc0/0xe0
[ 4.548053] __handle_domain_irq+0x74/0xd0
[ 4.551822] efi_header_end+0xb0/0xf0
[ 4.555500] el1_irq+0xd0/0x180
[ 4.558490] tegra_p2u_power_on+0x34/0x150
[ 4.562529] phy_power_on+0x98/0x110
[ 4.566445] tegra_pcie_enable_phy+0x68/0xf0
[ 4.570575] tegra_pcie_config_controller+0x138/0x450
[ 4.575726] tegra_pcie_config_rp+0x4c/0x250
[ 4.580166] tegra_pcie_dw_probe+0xa90/0x1040
[ 4.584635] platform_drv_probe+0x5c/0xb0
[ 4.588757] really_probe+0xf8/0x3d0
[ 4.592071] driver_probe_device+0x60/0xc0
[ 4.596097] device_driver_attach+0x78/0x80
[ 4.600207] __driver_attach+0x68/0xf0
[ 4.604147] bus_for_each_dev+0x84/0xe0
[ 4.608083] driver_attach+0x34/0x40
[ 4.611673] bus_add_driver+0x150/0x1f0
[ 4.615606] driver_register+0x68/0x120
[ 4.619713] __platform_driver_register+0x64/0x70
[ 4.624458] tegra_pcie_rp_init+0x24/0x2c
[ 4.628555] do_one_initcall+0x50/0x2f0
[ 4.632414] kernel_init_freeable+0x254/0x2d4
[ 4.636446] kernel_init+0x1c/0x118
[ 4.640367] ret_from_fork+0x10/0x24
[ 4.643906] Code: a9425bf5 a9446bf9 a8c77bfd d65f03c0 (d4210000)
[ 4.650035] ---[ end trace 0a0b55e447737d71 ]---
[ 4.654200] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 4.661917] SMP: stopping secondary CPUs
[ 4.665654] Kernel Offset: 0x3e82a4d70000 from 0xffff800010000000
[ 4.671693] PHYS_OFFSET: 0xfffff76340000000
[ 4.675825] CPU features: 0x8240002,03802a30
[ 4.680462] Memory Limit: none
[ 4.683508] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
What are you using now? Is it customized board?
Stop here for about 5s is expected.
From this log, do you connect any PCIe peripheral on your carrier board?
- I am using Jetson Agx Xavier Devkit
- Aside from a USB C hub, Ethernet, and HDMI and the Serial console connected to the host, I do not have any thing connected to the Jetson.
Could you help to use current Jetson Linux 35.2.1 | NVIDIA Developer release?
I’ve found there’s a similar kernel panic issue as yours.
Warming reset cause ccb errors - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
You could log that command line flash:
sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1 2>&1 | tee log_flash.txt
(then post the log as a file attachment)
Hi. this is the log file.
log_flash.txt (466.2 KB)
This solves the issue. Thank you so much. Im almost giving up.
