Hi everybody,
try update jetson kit TX2 with sdk 1.0.1.5538 (same issue with previous version) I have see in terminal :
2:56:40 ERROR : Flash Jetson TX2 : 1203: SKP: 57344( 14 blks) ==> 835725440:12
12:56:40 ERROR : Flash Jetson TX2 : 1204: RAW: 20480( 5 blks) ==> 835725452:20492
12:56:40 INFO : Flash Jetson TX2 : 1205: SKP: 8192( 2 blks) ==> 835745944:12
12:56:40 ERROR : Flash Jetson TX2 : 1206: RAW: 16384( 4 blks) ==> 835745956:16396
12:56:40 ERROR : Flash Jetson TX2 : 1207: SKP: 4096( 1 blks) ==> 835762352:12
12:56:40 ERROR : Flash Jetson TX2 : 1208: RAW: 16384( 4 blks) ==> 835762364:16396
12:56:40 ERROR : Flash Jetson TX2 : 1209: SKP: 20480( 5 blks) ==> 835778760:12
12:56:40 ERROR : Flash Jetson TX2 : 1210: RAW: 4096( 1 blks) ==> 835778772:4108
12:56:40 INFO : Flash Jetson TX2 : 1211: SKP: 8192( 2 blks) ==> 835782880:12
12:56:40 INFO : Flash Jetson TX2 : 1212: RAW: 8192( 2 blks) ==> 835782892:8204
12:56:40 INFO : Flash Jetson TX2 : 1213: SKP: 4096( 1 blks) ==> 835791096:12rminal this :
and also later
13:11:36 ERROR : CUDA Toolkit for L4T : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-9-0-local_9.0.252-1_arm64.deb" 5; sleep 5; ; safe_apt_install "sudo apt-get -y install cuda-toolkit-9-0 " 5 finished with error
13:11:36 INFO : CUDA Toolkit for L4T :
13:11:37 ERROR : CUDA Toolkit for L4T : command terminated with error
13:11:37 ERROR : CUDA Toolkit for L4T : install 'CUDA Toolkit for L4T' failure, command < cd '/home/emmanuel/nvidia/nvidia_sdk/JetPack_3.3.1_Linux_GA_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='eyJpZCI6Ik5WX0w0VF9DVURBX1RBUkdFVF9QT1NUX0lOU1RBTExfQ09NUCIsIm5hbWUiOiJDVURBIFRvb2xraXQgZm9yIEw0VCIsImRlc2NyaXB0aW9uIjoiQ1VEQSB0byBiZSBpbnN0YWxsZWQgb24gdGFyZ2V0LiBDVURBIGlzIGEg
13:11:37 ERROR : Unavailable components detected, please check log
13:11:37 ERROR : cuDNN on Target : cuDNN on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
13:11:37 ERROR : TensorRT on Target : TensorRT on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
13:11:37 ERROR : OpenCV on Target : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
13:11:37 ERROR : VisionWorks on Target : VisionWorks on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
13:11:37 ERROR : Multimedia API : Multimedia API Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
Update fails.
(With the previous sdk manager version I have the first block error but update arrived to the end.)
Laurent.
