I need to use L4T 28.3 on my TX2 for software compatibility reasons
When trying to flash the TX2 with L4T 28.3 on the TX2 DevKit I fail with exit message:
[ 2.3213 ] tegrarcm_v2 --boot recovery
[ 2.3225 ] Applet version 01.00.0000
[ 2.3412 ]
[ 2.3422 ] tegrarcm_v2 --isapplet
[ 4.0123 ]
[ 4.0937 ] tegradevflash_v2 --iscpubl
[ 4.0946 ] Cannot Open USB
The UART logs are:
[0051.007] E> Waypoint-0.5 ACK pending: 0x8
[0051.011] C> MTS error (2) : dram alias check failure
[0051.016] C> cpu waypoint 0.5 failed
[0051.020] C> ERROR: Highest Layer Module = 0x32, Lowest Layer Module = 0x32,
Aux Info = 0x1, Reason = 0x6
I can flash with L4T 28.4, so it is not an issue with my hardware nor host os setup.
I have tried with L4T versions 28.3.0, 28.3.1, and 28.3.2.
Here are the flashing logs (*.logs files) and the uart console logs (*.minicom files):
28.3.0
- tx2-Linux_for_Tegra_28.3.0-Ubuntu16.04-attempt-2021-06-23T15:16:24-06:00.log (23.2 KB)
- tx2-Linux_for_Tegra_28.3.0-Ubuntu16.04-attempt-2021-06-23T15:16:24-06:00.minicom (244 Bytes)
28.3.1
- tx2-Linux_for_Tegra_28.3.1-Ubuntu16.04-attempt-2021-06-23T15:22:04-06:00.log (23.2 KB)
- tx2-Linux_for_Tegra_28.3.1-Ubuntu16.04-attempt-2021-06-23T15:22:04-06:00.minicom (244 Bytes)
28.3.2
- tx2-Linux_for_Tegra_28.3.2-Ubuntu16.04-attempt-2021-06-23T15:23:41-06:00.log (23.2 KB)
- tx2-Linux_for_Tegra_28.3.2-Ubuntu16.04-attempt-2021-06-23T15:23:27-06:00.minicom (244 Bytes)
And here are the logs from the successful L4T 28.4 install:
- tx2-Linux_for_Tegra_28.4.0-Ubuntu16.04-attempt-2021-06-23T15:25:54-06:00.log (33.7 KB)
- tx2-Linux_for_Tegra_28.4.0-Ubuntu16.04-attempt-2021-06-23T15:25:54-06:00.minicom (225.0 KB)
Note: if you download these files they might say "cti-orbitty" at the beginning. Ignore that. I tested this on the devkit, but my logging tool automatically appends "cti-orbitty" to each file. This was done on the TX2 Devkit.
For diversity, I also tried flashing on the cti orbitty board but it fails with:
[ 2.4133 ] tegrarcm_v2 --boot recovery
[ 2.4152 ] Applet version 01.00.0000
[ 2.4379 ]
[ 2.4415 ] tegrarcm_v2 --isapplet
[ 4.1085 ]
[ 4.1113 ] tegradevflash_v2 --iscpubl
[ 4.1121 ] CPU Bootloader is not running on de
Of course, on the Orbitty I can’t get uart, so I don’t have uart logs for “CPU Bootloader is not running on device” failures, only for “Cannot Open USB”
I have also previously reported the downstream issue this causes in Jetpack 3.3.2 and 3.3.1 in these threads:
