Flashing with SDKManager - completeSetup failed
I tried to flash with the most recent version of sdk.
i followed the instructions, set recovery mode, sdk detected the device, downloaded everything, build image and failed when flashing it
In the logs i can only find:
error: completeSetup failed. Error:
error: install process failure
what can i do?
SDKM_logs_JetPack_4.6_(rev.1)_Linux_for_Jetson_AGX_Xavier_2021-09-15_11-12-54.zip (128.1 KB)
Your log says you don’t put the board into recovery mode at all. Please make sure you are using J512 type C port.
Only this port can do the flash.
"/home/br/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/flash.sh"  jetson-agx-xavier-devkit mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 6.1
Error: probing the target board failed.
       Make sure the target board is connected through
       USB port and is in recovery mode.
*** ERROR: flashing failed.
