Flashing
When the first flashing system uses this command( sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal), what parameters are added when the second burning, which can shorten the flashing time?
I’m not quite sure what are you referring to.
Do you mean this?
Tips:
- The tool also provides the --keep option to keep the flash
  environment, and the --reuse options to reuse the flash environment to make
  massflash run faster:
  Massflash the first time.
  $ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5 --network usb0 --keep
  Massflash the second time.
  $ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 5 --network usb0 --reuse
I mean, with the brush command, after the brush success, there is a mirror, the next brush will not have to repeat the production of the mirror, because the production of the mirror is very time-consuming, on the basis of the original command to add -flash-only, can quickly brush the existing mirror?
如果你不想要花時間再重新建image的話,就跟你說的一樣用--flash-only這個參數就好
–no-flash 和 --flash-only 的用法有介绍链接吗 ? 如何使用,在哪个位置添加?
比方說你原本的flashing command長這樣
你可以第一次先加上--no-flash
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 --no-flash -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal
後面的參數會被存在Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt所以可以不用加
要實際flash的時候直接用
就好
1.–no-flash的含义是什么?
2.我第一次没加–no-flash, 接下来我能直接用sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only 这个命令刷机吗?
就是只產生image但是不實際flash,如果你觀察完整的flashing log的話可以發現
initrd flash的流程實際上也是分成第一次先用--no-flash產生image,第二次再用--flash-only燒進去
可以
哦哦,- -no-flash只是制作image, 不刷机; - - flash-only 只刷机,不产生image; 我最初的那个命令式制作镜像和刷机同时完成了,接下来在刷机,只用flash-only就可以了,是这样的吧
沒錯,但是請確定你是用同樣的device和storage(比方說都是Orin Nano+NVMe)
image才能重複使用
好的,谢谢
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only 这个命令完整吗? 后面需要跟上nvme0n1p1 或者其他什么参数?
不用,我這裡有說了
