Flashing
agx orin 64G模组,生产批号显示为25年的模组,看官方资料显示模组更新了DRAM和EMMC, 我们恢复备份的镜像时,发现不能进行镜像恢复了,我们想知道模组算是较之前算更新了,是不是有新的备份和回复镜像的方法?
The Jetson AGX Orin 64GB-DRAM (P3701-0005) is a production module that is compatible with the Jetson AGX Orin reference carrier board (P3737-0000). It is flashed with QSPI-NOR and eMMC, and its configuration is described by the jetson-agx-orin-devkit configuration.
In comparison to the Jetson AGX Orin 32GB-DRAM (P3701-0004), the main difference is the amount of memory. The Jetson AGX Orin 64GB-DRAM has 64GB of memory, whereas the Jetson AGX Orin 32GB-DRAM has 32GB of memory. Additionally, the production Jetson AGX Orin 64GB and Jetson AGX Orin 32GB modules have different AI compute and performances.
It’s also worth noting that the Jetson AGX Orin Developer Kit has been upgraded with 64GB of memory, and its performance is the same as the original 32GB Jetson AGX Orin Developer Kit, except for the memory. The price of the Jetson AGX Orin developer kit with 64GB of memory is $1999.
In terms of the configuration, the Jetson AGX Orin 64GB-DRAM (P3701-0005) is flashed with QSPI-NOR and eMMC, which is the same as the Jetson AGX Orin 32GB-DRAM (P3701-0004). However, the jetson-orin-nano-devkit-super.conf configuration has a higher power budget and extended clock-frequency steps compared to the jetson-orin-nano-devkit.conf configuration.
Overall, the Jetson AGX Orin 64GB-DRAM (P3701-0005) is a production module with 64GB of memory, compatible with the Jetson AGX Orin reference carrier board, and flashed with QSPI-NOR and eMMC. Its configuration is described by the jetson-agx-orin-devkit configuration, and it has different AI compute and performances compared to the Jetson AGX Orin 32GB-DRAM (P3701-0004).
That seems to be related with PCN211462
So your original image can’t boot up this new module, right?
Then you will need to integrate the relevant patch on your original SW to flash this new modle, afterward you can create a new image based on this SW for all your old and new modules.
我打上补丁试一下, 稍后回复您
