When try to flash on Pegasus, installation button is disabled.
And host PC is also 16.04 so it should be work(and several month ago it was working), but Now it doesn’t work.
I attached image capture, and “TARGET OPERATING SYSTEM” disabled, and “CONTINUE TO STEP 02” also disabled. I also check after connect to Pegasus, but also same symptom.
And if i select another Target Hardware, it is enabled.
Software Version
after I plug-in to xavier debug port and checked lsusb, it looks like recognize usb.
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 014: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 013: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 012: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 011: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 010: ID 0424:2807 Standard Microsystems Corp.
Bus 001 Device 004: ID 8087:0aaa Intel Corp.
Bus 001 Device 003: ID 5986:211c Acer, Inc
Bus 001 Device 002: ID 1038:1122 SteelSeries ApS
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I knew that you encountered some issues with the installation and are working with our colleague.
Our team has made some updates to the installation. Please try it again. Thanks.
