Is it possible to add custom force to single particle in flex?
In flex I’m completely new and suffer form lack of simple samples like those in PhysXSDK.
Does anybody found some basic examples less complicated than flexDemo?
Hi
I am currently doing some research in the FleX framework.
The demo is indeed quite overwhelming at first glance.
I’m afraid there are no other references for FleX.
As far as I know, there is no way to add a force to a single particle except from explicitly setting the position of the specific particle each frame.
Thanks for the answer.
I will wait until Flex will be more documented and more examples will appear.
For now I moved to CudaSDK to complete my task.
Regards,
MG
