Hi everyone,
I would like to execute the samples from Flexio. After running build.sh
and check_compat.sh
, the output indicated success. However, when I attempt to run the flexio_rpc
sample, I receive the following error message:
Here are the outputs from build.sh
and check_compat.sh
root@localhost:/opt/mellanox/flexio/samples# ./build.sh
The Meson build system
Version: 0.61.2
Source dir: /opt/mellanox/flexio/samples
Build dir: /opt/mellanox/flexio/samples/build
Build type: native build
Project name: flexio-sdk samples
Project version: 0.1.0
C compiler for the host machine: cc (gcc 11.4.0 “cc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0”)
C linker for the host machine: cc ld.bfd 2.38
Host machine cpu family: aarch64
Host machine cpu: aarch64
Dependency libibverbs found: YES 1.14.54.0 (cached)
Dependency libmlx5 found: YES 1.25.54.0 (cached)
Dependency threads found: YES unknown (cached)
Dependency libflexio found: YES 24.10.2454 (cached)
Program doca_build_dpacc.sh found: YES (/opt/mellanox/flexio/samples/doca_build_dpacc.sh)
Build targets in project: 6
flexio-sdk samples 0.1.0
User defined options
buildtype : debugoptimized
default_library: static
warning_level : 3
werror : true
cpu : bf3
Found ninja-1.10.1 at /usr/bin/ninja
ninja: Entering directory `/opt/mellanox/flexio/samples/build’
ninja: no work to do.
*** THE BUILD IS SUCCESSFULLY FINISHED IN THE “build” FOLDER ***
root@localhost:/opt/mellanox/flexio/samples# ./check_compat.sh
Version: 0.61.2
Source dir: /tmp/check_comp
Build dir: /tmp/check_comp/build
Project version: 1.0
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Run-time dependency libibverbs found: YES 1.14.54.0
Run-time dependency libmlx5 found: YES 1.25.54.0
Run-time dependency threads found: YES
Run-time dependency libflexio found: YES 24.10.2454
Build targets in project: 1
ninja: Entering directory `build’
[2/2] Linking target test_host
- Compatible check passed *
I have two machines with the same DPU model, but only one is displaying errors. Can anyone offer suggestions?
Thank you!
