I’m trying to make a loop with a while, but while function doesn’t accept float* as an argument to stop.
I have a few questions about this type of declaration:
What is float*?
What’s the diference between float* and float?
And how do I transform float* in to float?
Thanks,
Thiago dos Santos Pinto
Brasil
A float * type is a pointer to a float variable.
You don’t convert a float * into a float… they’re different things. But you can dereference it to access the float value it points at by prepending a “*” to the variable. So for example,
float *a=somePointer; // can also be written float* a or float * a
float b = *a; // dereference it
This is all just like classic C (not GPU specific) so all the classic C references can explain it.
