Hi, the following code fails on my Jetson TX2 with tensorflow 1.9.0&CUDA 9.0:
import tensorflow as tf
tf_float = tf.float16
device = '/device:GPU:0'
with tf.device(device):
queue = tf.get_variable(name="SomeTensor",
initializer=tf.ones([1],
dtype=tf_float),
dtype=tf_float,
trainable=False,
collections=[tf.GraphKeys.LOCAL_VARIABLES])
write = tf.scatter_update(queue, 0, 2).op
with tf.Session(config=tf.ConfigProto(log_device_placement=True)) as session:
session.run(queue.initializer)
session.run(write)
The error message:
InvalidArgumentError (see above for traceback): Cannot assign a device for operation 'SomeTensor': Could not satisfy explicit device specification '/device:GPU:0' because no supported kernel for GPU devices is available.
Colocation Debug Info:
Colocation group had the following types and devices:
ScatterUpdate: CPU
Assign: CPU
Identity: GPU CPU
VariableV2: GPU CPU
Colocation members and user-requested devices:
SomeTensor (VariableV2) /device:GPU:0
SomeTensor/Assign (Assign) /device:GPU:0
SomeTensor/read (Identity) /device:GPU:0
ScatterUpdate (ScatterUpdate) /device:GPU:0
Registered kernels:
device='CPU'
device='GPU'; dtype in [DT_INT64]
device='GPU'; dtype in [DT_DOUBLE]
device='GPU'; dtype in [DT_FLOAT]
device='GPU'; dtype in [DT_HALF]
[[Node: SomeTensor = VariableV2[container="", dtype=DT_HALF, shape=[1], shared_name="", _device="/device:GPU:0"]()]]
Suggests that scatter_update cannot be placed to GPU.
Everything works fine with tf.float32 data type. I can also place scatter_update on CPU.
Am I doing something wrong?
Is there any way to fix this?
Thanks a lot in advance for any help.
