Float3 Memory Allocation in CUDA
How is memory allocated by CUDA on the host and device for the special CUDA datatypes like float3?
For example if I declare an array x as follows
float3 x[2];
how are the components allocated in memory? Is it
x11,x12,x13,x21,x22,x23
or is it
x11,x21,x12,x22,x13,x23
where the first index is the index in the array and second index is the index within the float3 datatype.
Just like it is in normal C. Otherwise memcopies will not work.
