Floating Joint Visualizing URDF
I’m trying to get the cylinder link below to be mounted to base_tail_seg(a moving object) with a floating joint such that the cylinder can move freely(like a ball joint), and while this urdf runs without errors, the cylinder still looks fixed in Isaac Gym. Is there anything else we need to add in order for us to visualize the cylinder moving?
<joint name="base_static_joint2" type="floating">
    <origin rpy="0 0 0" xyz="0 0.15 0"/>
    <!-- <origin rpy="0 0 0" xyz="0.048 0 0.058"/> -->
    <parent link="base_tail_seg"/>
    <child link="tail_seg1"/>
    <calibration rising="0.0"/>
    <dynamics damping="0.0" friction="0.0"/>
    <limit effort="30" velocity="1.0" lower="-3.14" upper="3.14" />
  </joint>
  <link
    name="tail_seg1">
    <inertial>
      <origin
        xyz="0.00793179544277737 2.48115460577673E-19 0.0312047945759253"
        rpy="0 0 0" />
      <mass
        value="0.5"/>
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="-1.57 0 0" />
      <geometry>
        <cylinder length="0.15" radius="0.006"/>
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0.03"
        rpy="0 0 0" />
      <geometry>
        <!-- <mesh filename="../meshes/sagittarius_base_link.obj" /> -->
        <box size="0.25 0.1 0.05"/>
      </geometry>
      <child link="tail_segment1"/>
    </collision>
  </link>
