I ran pgdbg and it trapped the following error …
Signalled SIGPFE at 0x7F54717D91A8, function __hpfio_ftm_g
can anyone help explain this error or what the hpfio_ftm_g function is
thanks,
Hi jimf787,
“hpfio_ftm_g” is a Fortran I/O routine which converts a “G” format value into a printable string. A SIGFE is a floating point exception such as an underflow, overflow or divide by zero.
Do you compile the “-Ktrap” flag? What values are you trying to print with the “G” format? Could you be dividing a value by zero?
- Mat
