I have a newton raphson loop where I have the following:
lambda -= delta;
typically, I have to do an operation such as:
lambda = 52347.592
delta = 0.001542
and then I end up with terribad floating point rounding errors since floating point operations can only support approximately 7 significant digits.
I’d very much prefer to stay away from doubles if possible due to its terrible floating point performance.
edit: after some more investigation - seems like I need to change a lot of floats to doubles - give me a 50% penalty in running time… sigh.
Apparently doubles run at 1/10th the speed of single precision floats
