I just installed the CUDA SDK and Toolkit on my Debian system.
Running most examples seems to end successfully but when trying fluidsGL I get this:
freeglut ERROR: Function called without first calling ‘glutInit’.
Thank you, do you have any tips on how I should diagnose this further, I have tried with make dbg=1, then it gives some more information in the cases where it fail (unspecified error, or something like that, im not at the machine now)
There are a lot of possible causes … :(
Are you running on the required RH release, 97.51 driver, 32bit Linux kernel, …
What do you see in /var/log/messages
Check /var/log/xorg.log
Does the machine freeze when playing a game? (power supply inadequate?)
For the record, I am running openSuSE 10.2: default kernel 2.6.18, glibc 2.5, NVIDIA 97.51 driver, 8800GTX
300W sounds a bit weak, but that is only the intake. Depending on the efficiency of the power supply, check that it can actually output the required 30 Ampere (GTX) or 26 Ampere (GTS) on the 12 Volt rail (and has something left for the processor). Also check that you connected both power connectors (it does work with one, but not at full speed).
Now I have tried this graphics card
on linux, windows, 2 different computers and the same result in each case,
fluidsGL run correctly in about 50% of the tries.
Does it sound like i have gotten a faulty card ?
I don’t think this is related to the PSU. I have a 450 W (25 A @ 12 V). On windows, I can run FEAR (max quality @ 1680x1050) for many hours without a glitch. On linux I can’t say for sure that the driver is OK … I don’t know any valuable benchmark.
