Flutter w Jetson Orin Nano
Hi. Im trying to use flutter .But I did all setups and still while ı used the “flutter” command.Im getting always this error: “NvRmStream: Illegal stream pointer (err=4)” and flutter doesn’t work.Can you help me please
Based on Flutter’s doc, it doesn’t support the Jetson system:
Please check with the Flutter team for more info.
So Can’t I use the my flutter application on Jetson?
Please check with the Flutter team.
They should know more about the status of Flutter.
