Operating System:
Windows
GPU Hardware:
A series (Blackwell)
GPU Driver:
Latest 581.80
I am following this FLUX2 model and try to use it with my Blackwell Pro 6000
I have serious issues, please help if you can.
Phase 1: Initial Blocking
📝 FLUX.2 Workflow Loading Failure (ComfyUI Portable)
Environment & Goal
System/Setup: ComfyUI Portable (Windows) on an NVIDIA RTX Pro 6000 GPU.
Goal: Load and run the official Stability AI FLUX.2 model.
File Status: All necessary model files are downloaded and confirmed to be in their correct model subfolders:
diffusion_models/:flux2-dev.safetensors -
vae/:ae.safetensors -
text_encoders/: 10 sharded files (model-00001-of-00010.safetensors…) +model.safetensors.index.json
Chronological Troubleshooting Summary
Issue
The original workflow failed immediately due to the FLUX.2 Text Encoder being split into 10 sharded files, requiring custom assembly logic.
Required Fix: Install the specific FLUX custom nodes (
Load Diffusion Model (FLUX),Load CLIP (FLUX), etc.). -
Blocker: The ComfyUI Manager is blocked from installing new custom nodes via Git URL due to a security/portable config restriction (Error:
This action is not allowed with this security level configuration). -
Result: The model cannot be loaded, producing a
RuntimeError: mat1 and mat2 shapes cannot be multiplied...when the standard system tried to process the sharded Text Encoder.
Phase 2: Workaround (Bypassing Custom Nodes)
To bypass the installation block, the three custom FLUX loader nodes were deleted and replaced with a single, generic Load Checkpoint node.
Blocker: The
Load Checkpointnode exhibited a bug where its dropdown was blank/empty and would not list the availableflux2-dev.safetensorsfile, despite it being correctly placed. -
Fix Applied (Manual JSON Edit): After extensive searching, the saved workflow JSON was located in a temporary folder. The file was manually edited to hardcode the model name:
- Changed
"widgets_values": [null]to"widgets_values": ["flux2-dev.safetensors"]in theLoad Checkpointnode block.
- Changed
Fix Applied (Connections): After loading the edited JSON, the model was manually connected: MODEL $\rightarrow$
BasicGuider, CLIP $\rightarrow$CLIP Text Encode, and VAE $\rightarrow$ twoVAE Encodenodes (as shown in the final workflow image).
Phase 3: Current State (Final Error)
With the workflow fully connected and pointing to the model file, the execution stopped at the SamplerCustomAdvanced step, generating the definitive error in the console:
KeyError: 'text_model.encoder.layers.0.mlp.c_fc.weight'
Conclusion & Request for Assistance
The KeyError confirms that the standard Load Checkpoint node, even when manually configured, cannot assemble the sharded Text Encoder weights from the separate files in the text_encoders directory.
The system is definitively blocked by the missing custom code.
We request assistance with one of the following:
A manual, command-line, or direct file-copy method for installing the required FLUX custom nodes without using the blocked ComfyUI Manager/Git functionality.
Guidance on a native ComfyUI configuration (e.g.,
extra_model_paths.yamlor a specialized node) that can correctly load the sharded Text Encoder files alongside the main checkpoint.
Thank you for your expertise. We have exhausted all standard workarounds.
Pekka Varis
